First post, by ratfink
- Oldbie
I recently obtained a K7D with dual 2800 cpus. I don't really have room for another build but I'm wondering how it would compare to a s775 prescott 640 [3.2ghz] for running XP and 2000, dx9/dx8 games and videotape conversion/encoding. Both will probably have ddr ram.
I'm thinking there is probably not a massive between them but the prescott will be somewhat faster on single tasks, and the dual athlons will be better at multi-tasking as it's two real cpus rather than hyperthreading on a cpu with a long-pipeline. For my intended usage - with little need for multi-tasking as this is not my main pc - there is probably no point in setting up the athlon system.
Or would the athlons be just as quick plus be better multi-tasking?
