First post, by tayyare
- Oldbie
I already had a nice, working copy of an XP machine with the below mentioned essentials (which was my main rig till mid 2009):
AMD Athlon 64 3700+
Asus K8N-E Deluxe 3GB (1GB x 3 Kingston DDR 400)
Sapphire ATI Radeon HD 3600 512 MB AGP
Sound Blaster Audigy 2 ZS SB0350 PCI
plus HDDs, DVDRWs, floppy, SCSI controller, etc.
I recently tried to make an upgrade with some parts that I scored locally for reasonable prices:
Asus K8N4-E Deluxe (with PCIe slot)
Sparkle nVidia 98000GX2 PCIe
Board works like a charm, but since I made a very noob mistake, GX2 does not (too big to install into current case and I definitely not want to change the case) so it temporarily has a PCI Radeon 9250 at the moment as GPU.
While I was checking local ebay equivalents for suitable size G92 cards, I also find a new and boxed Asus A8N-SLI Deluxe coupled with an AMD Athlon X2 3800+ for 60 USD. I also find the short V92 of my choice (ZOTAC GeForce GTS 250 ECO 1GB) for 35 USD, and the seller has more than one on hand.
So there is a new opportunity. I can easily go for just one of the Zotac's and be happy, or buy the new CPU/mobo combo and one more ZOTAC to try a SLI setup. In addition to having a SLI setup, it has support for 4GB RAM (3GB max with my current board) and CPU upgrade options up to AMD Athlon 64 X2 4800+ or FX60 (current mobo has only up to Athlon64 3700+/Turion64 4000+). On the down side, the additional cost will be about 100 USD.
Purpose of this machine at the moment is playing games that works under XP and from 2000-2007, running some obscure software which are not happy with Windows 7 (like my old trusty AutoCAD Light 2002) and as a backup machine to my main rig. The role will not be changed in the foreseeable future.
So, mates, what do you think?
- Does 100 USD worth for the additional power that I would get? (K8N4E/A64 3700+/GTS250/3GB vs. A8N-SLI/AX2 3800+/GTS250x2 SLI/4GB)
- If it does, then, does 65 USD more for a Athlon 64 X2 4800+ compared to combined Athlon X2 3800+?
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
