First post, by DoomGuy II
This may not be much of a retro topic, but it falls into the category of having a more modern system with an internal floppy drive for transfers and such between it and my older systems. I have a Dell Dimension E521 that I've maxed out a few weeks ago with an AMD Athlon X2 5600+, 4MB RAM, and a Geforce 9400 GT (plan to at least upgrade it to a 9800GT since I got an 850W PSU in there). So, I was wondering what would be the last computer or motherboard to support internal 1.44MB high-density disk drives. Sure there are external floppy drives, but I feel that they're not as effective as an internal one.
Official Website: https://dg410.duckdns.org/
Reply 1 of 6, by ODwilly
Some AM3+ motherboards. I use the AsRock Extreme4 990fx and love it.
Reply 2 of 6, by firage
ASRock still had an onboard floppy connector on their Z77 based motherboards.
My big-red-switch 486
Reply 3 of 6, by smeezekitty
Asrock is a place to look. Many of their later boards have them
My G41M-S3 with a BIOS date of 2011 has one
Reply 4 of 6, by mockingbird
Yes, ASRock Fatal1ty boards had them...
But it must be going through a PCI bus to PCIe express bridge chip.
The last Intel chipsets to support PCI natively were B65, B75, Q65, Q75, Q67, and Q77.
I believe even the AMD 990 still supports native PCI.
(Decommissioned:)
Reply 5 of 6, by obobskivich
mockingbird wrote:
Yes, ASRock Fatal1ty boards had them... […]
AMD 970/990 is older, compared to modern Intel offerings (it's been out for a few years) - that isn't a bad thing, especially if you want more legacy support features. AM2+ boards with 790 can also be useful (they should support AM3 CPUs, depending on BIOS support), and may have more PCI slots than modern boards.
I know my ASRock Z97x does not have floppy/PATA/PCI at all (curiously it does have a header for serial though). USB external drives would be an option on something like that.
Reply 6 of 6, by PhilsComputerLab
AMD seems a good option. My only AMD machine is my capture computer in my lab, because it has a FDD port for the GOTEK floppy emulator. I use it very often!
