First post, by zeitenwandeler
Hello,
I tried to get the game "Aufschwung Ost" run. In the beginning everything seems to be good. But when I have to choose the "Szenario" the game gets frozen. I changed dosbox.conf as described on www.dosbox.com, but the problem remains.
Do you have an idea, what to change?
I use "win xp" and "dosbox 0.74".
I'm thanking you in anticipation.
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Be sure to run AOCONFIG.EXE and select option 3 for SoundBlaster sound, which should autodetect PORT $0220, IRQ #7 with default settings in DOSBox. Having the wrong IRQ number in AO.INF will cause the game to freeze (hang) at the place you refer to.
Reply 2 of 2, by zeitenwandeler
Perfect! Now it runs.
Thank you very much!!
