Issue with Blood + AWE64 Gold
Reply 40 of 47, by MrEWhite
Autoexec.bat:
SET SOUND=C:\PROGRA~1\CREATIVE\CTSND
SET MIDI=SYNTH:1 MAP:E MODE:0
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
C:\WINDOWS\CTCM
C:\Progra~1\Creative\CTSND\AWEUTIL /s
PATH=C:\WINDOWS;C:\
Config.sys:
DEVICE=C:\WINDOWS\HIMEM.SYS
DOS=HIGH,UMB
DEVICE=C:\Windows\EMM386.exe NOEMS
FILES=30
STACKS=0,0
BUFFERS=30
Dosstart.bat:
C:\WINDOWS\CTCM
Reply 41 of 47, by j^aws
BTW, have you edited MSDOS.SYS as instructed in the previous page? If you haven't then it's highly advisable that you do; it makes testing so much easier in DOS.
Start with:
1) Delete both entries in DOSSTART.BAT:
C:\WINDOWS\CTCM
2) Delete this in AUTOEXEC.BAT:
C:\WINDOWS\CTCM
Then run DIAGNOSE.EXE in C:\PROGRA~1\CREATIVE\, and test. If okay, then save at the prompt. This should update your files.
Then run the sound setup for BLOOD, test and run game. See how you get on. If having issues still, post the contents of the above files again.
Reply 42 of 47, by MrEWhite
There is no diagnose inthe Creative file.
Reply 43 of 47, by j^aws
Delete these in AUTOEXEC.BAT:
C:\WINDOWS\CTCM
Delete these in DOSSTART.BAT:
C:\WINDOWS\CTCM
Download this:
The attachment AWE64DOS.rar is no longer available
... And extract to C:\, so that you have C:\AWE64DOS, then run DIAGNOSE.EXE from that directory. Then follow what I posted above.
Reply 44 of 47, by MrEWhite
Could you put that in a zip?
Reply 45 of 47, by j^aws
I don't have Winzip installed. IIRC, it should be able to extract .rar files. If not, Winrar is available online.
Reply 46 of 47, by MrEWhite
I think I fixed it by setting the IRQ to 7...
Reply 47 of 47, by j^aws
^ That's good to hear; enjoy the game.
