Reply 100 of 472, by keropi
- l33t++
a WIP photo, just finished replacing the caps I already had, now waiting for the rest to arrive:
The AT (left) psu was way easier to work with , the ATX is too crammed... not all caps are seated all the way to the pcb, some of my caps are slightly bigger - most notable the 2200uf one near the cables... meh
I also used silicone to glue together the caps on the ATX psu like the manufacturer had , just in case the cables start pushing them.
The 3 blue caps on the ATX psu are Vishay 220uf ones, AFAIK these are OK and originated from Philips... I hope they are ok 🤣
