First post, by Turboman
- Member
I have this DP6NS board on this board I can jumper the speed of the CPU from 150 up to 300, right now I am using 200mhz 1mb and sometimes it will show 200mhz and other times it will show 100mhz and will not boot or freeze randomly at the load screen. Sometimes it does it with only 1 CPU and other times it does it with both. I've done just about everything I can from using different CPU, PSU, Ram, Bios update and clear Cmos etc. I also checked all the caps with a scope and they seem to be fine. The one thing I have noticed and this is the reason I am asking is there are two regulators EZ1085CT that according to the datasheet are supposed to output 3.3v and they are giving 1.5v output, 3.5v input and 0.25v adj/gnd on each one I don't know if this is how it is supposed to work or not. The SC STP8 seems to be working correctly I get 3.5V collector and 5V on the emitter.
The other problem I am having is if I fill up all the ram banks it will freeze or sometimes display jumbled mess of characters when booting. This only happens if the last two ram slots are filled the ones closest to the CPU. This board can take up to 768mb but I've tried different combinations same issue if the last two are filled. Nothing appears to be physically damaged. Last thing is the very bottom surface mounted cap next to the bios chip is not full ground it's partial only and every other cap is full ground is this normal? If anyone could tell me what else I should do, thanks
http://pdf1.alldatasheet.com/datasheet-pdf/vi … H/EZ1085CT.html
http://www.datasheetarchive.com/dlmain/Datash … /DSA-151499.pdf
