First post, by Stojke
- l33t
What is the additional power input for this socket two board? Also, what is this socket 2 board? 🤣
I find out it is an Intel Chipset 420TX motherboard with PCI 1.0 interface. It has an OverDrive Socket 2 CPU socket. 5 ISA and 3 PCI slots. FPM memory (chipset specified).
The board came with an AMD 486 DX2 66MHz 5V CPU (voltage info not present but I read that the chipset is 5V). It has no silk screen information at all except 1993 AMIBIOS and some shorts. Dallas chip is not socketed, so fuk their momma.
Are these boards worth anything today? If so what PCI cards fit onto them?
