First post, by TheDosPlace
Hi everyone.
I would like to suggest a very very very small change to the CSS for the board theme to improve usability:
dt[title="No unread posts"] a.topictitle { font-weight:normal; }
This will make the links to threads which have no unread posts appear with a normal font-weight instead of bold, like this:
What do you think? Opinions? Disadvantages?
Dave
^Dave from TheDosPlace
http://www.facebook.com/TheDosPlace
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
The username below it is bold as well. (In fact all links are bold). Not sure if I like the username being bold while the topic itself isn't
Water flows down the stream
Reply 2 of 2, by TheDosPlace
Hi Qbix,
Thanks for the reply. That can be fixed by extending the CSS a little:
dt[title="No unread posts"] a.topictitle,
dt[title="No unread posts"] a.username-coloured
