First post, by Megadisk
I was given two old Western Didital HDD's that I can use in my Sega Teradrive PC, but they both have lots of problems or bad clusters. One is a WDL-330P (30MB) and the other is a WDL-320 (20MB). How does one goes about doing a low-level (or physical) format on these drives?. I remember a so called "Everex Everdisk" software that could do this on the fly but can't seen to find it anyware. Any help or ideas are greatly appreciated.
Reply 2 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I'm not familiar with the Teradrive PC -- what kind of HDD controller are you using?
Once upon a time, I had a Seagate ST-251-1 HDD connected to a Western Digital WD1003V-MM2 controller. The controller BIOS contained a low-level format program that you could run in the DOS debugger from a boot floppy. The command in DEBUG.EXE was "g=c800:5", but I think the entry address can vary depending on the controller brand/model and BIOS version.
Reply 3 of 4, by Kodai
A quick note for those who use the HDD controller on a MFM or RLL drive to do a low level format. Depending on the size, it can take a REALLY long time. I had to do it quite a bit in the 80's and some drives like say 40MB could take a good 36+ hours. Worked like a charm, but is a very slow method. The very rare ADRT required any RLL drive hooked up to it be low level formatted but was very quick at the job. I remember doing several 30-80 MB drives in less than a couple hours each. Well worth it if you can find one, but don't use an MFM drive with it. It will work, but the life of the drive will drop like mad. I found that out the hard way.
On a side note, you can still use that debug command with one other little option (I'm not going to say what it is), to start a low level format on a modern IDE drive and make it so the drive cant be read under any normal recovery. To fix it so it will read again, one has to pull the platters out and use a special machine used in crashed HDD recovery labs while known what the problem is to correct it. I actually had a job back in the 90's where I had to do this to many drives to prevent data from ever being read form them. In essence it destroys the drive unless you are willing to spend $5,000.00+ to fix it and even know what the problem is as well as the solution. It was the perfect way to leave a drive functioning but show it had a "mysterious" crash. I was not at all pleased with that job to say the least.
Reply 4 of 4, by tayyare
Beegle wrote:
Bumping because I have received a 10MB hard drive recently and plan on doing a low-level format too.
Older versions of Ontrack DiskManager will be good for this. I don't remember the version, but during the early 90s, I was using one came with a Seagate drive (in a 5.25" 360 KB disk, no less 🤣) with ease, for the exact same job. It was working for both IDE and MFM/RLL drives IIRC. Newer version might also work but I have no MFM drives left when I started using them.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
