Recently did a fresh install of OS/2 v4 on this K6-2 350 box with 256megs of ram, Which runs win2k normally. It was a piece of cake, so decided to see how my old v4 FP14 4gig hdd installation went. I'm typing this on an early version of firefox called FireBird I installed back in 2002 or thereabouts on a completely different system. It's not ideal so will see if I can get SeaMonkey up and running. No issues with cdroms at all either.
The attachment os2_mark.jpg is no longer available
Using a SMC ISA nic at present until I find a suitable supported pci nic. Having Scitech display driver installed makes it easier to move the hdd from one sytem to the other. I've ran this hdd on 4 different systems so far. The sound card that will go into this will be a SB16 as it's been set up in OS/2 from my old installation and I'll fit an early APG graphics card.
Purely setting it up for nostelgic purposes with a bit of fun in the process.
I've got v3 set up, no fixpacks, on my DECpc with 486dx2/66, 16megs of ram, SB sound card, DE-220 nic on a 400meg hdd with v4 servers network client which is better than the the"Connect" offering because it gives you DHCP support.
The attachment pmirc.jpg is no longer available
Both systems are connected up to my bb router via a 10/100BaseT switch which is alo shared with my 286/12 running dos/win3.1/trumpet winsock with a GeniusLan nic and my 386DX25 which runs WfW 3.11 with TCP32b installed using another DE-220 nic. There's also a P200mmx RH Linux 7.3 in the mix.
First advice I'd give is update disks 1 & 2 and make sure all your hardware is supported and performing well. Al Savages guide will be useful as well http://asavage.dyndns.org/os2/warp4install/warp4install.html From my limited experience even with compatible hardware OS/2 can trip up at times.
To say Windows NT and OS/2 are closely related couldn't be farther from the truth..but is likey the a system that plays nice with NT should work fine in OS/2. No point in having multiple cpus though. NT supports that out of the box OS/2 certainly doesn't.
The Blue Spine v3 Connect box has a leaflet advising Aptiva owners to contact an IBM service reps. A quick search shows a number of fixes for certain models from changing ram, bios changes to a software fix.
Hmm memory does funny things. Discovered I had Mozilla on here so can now insert bics from this boxx.
The attachment os2_mark3.jpg is no longer available
