First post, by squareguy
I am requesting high resolution photos of the Sound Blaster 16 CT2940 with and without the OPL3 chips and DAC. I am beginning to think I will never get to buy a CT2940 with the OPL3 so what I want to do is take the parts from a CT2900 and install the on a CT2940 and remove the CQM parts. If successful I will post pics and data of the transplant. It will take a little reverse engineering and some free time (which I have little of) but should be able to get it done over the summer.
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 2 of 14, by squareguy
What a shame to destroy that card.
Windows 98 SE
Reply 3 of 14, by JayCeeBee64
Rank Retired
Retired
Here's an old VOGONS thread with some info that may be relevant. The last post has a link to a CT2940 w/CQM pic:
Creative CT2890 PnP vs CT2940 (Sound Blaster 16 models)
Here's a post from dave343 with pics from a CT2940 w/OPL3:
Whats the best version of the Sound Blaster 16?
And just in case, here's a CT2900 pic I found some time ago:
As for your proposed transplant, I second what firage said - good luck, you will definitely need it.
Ooohh, the pain......
Reply 4 of 14, by squareguy
It is interesting that crystal X3 is used in the CT2900 but not for the CT2940.
Windows 98 SE
Reply 5 of 14, by Great Hierophant
X3 is used on my CT-2940, which has an Yamaha YMF-289 OPL3-L and YAC-516 DAC.
Reply 6 of 14, by squareguy
Hmmm odd, might be optional but is definitely for the OPL3/DAC
Windows 98 SE
Reply 7 of 14, by Cloudschatze
It's not optional if the Yamaha chipset is present. It was already determined that the crystal had broken off of the card in that photo.
Reply 8 of 14, by squareguy
Thanks for the info
Windows 98 SE
Reply 9 of 14, by Agent of the BSoD
I think I actually found a CT2940 recently at a local computer recycling center. Should still be there, nobody looks for these retro parts here. I have no idea whether it came with the OPL3 or not, I lack pictures of that card when I was taking them for certain parts to look up later as my camera was almost out of power. I should take another peek at it again.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | ESS 1688 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 10 of 14, by squareguy
Send it to me 😉 I will be your best friend!
Windows 98 SE
Reply 11 of 14, by Agent of the BSoD
Alas, said place is not open until Monday. Would be a bummer too if it doesn't have the OPL3 chip.
Edit: Actually, looks like I did have a partial picture of it, just the left side though. From the design of the PCB and using the power of Google, it looks like it's one without the OPL chip. 😒
Reply 12 of 14, by Agent of the BSoD
Yep, it's as I thought it was going to be. Uses CQM instead of OPL3.
http://i.imgur.com/IclOD9O.jpg
Reply 13 of 14, by Jepael
I thought the same, and I got the half that contains the OPL chip!
