First post, by Marty2dos
Hello @ll
I'm a Gamer (most oldgames) and Hobby programmer and Adminstrator (at work).
In my free time i try to fix old games to run on modern Systems. Now it is one of them,
the updates of old games to fix to run without CD. The most updates for the German
Versions from the Old Games era are forgot.
Hidden NoCD from the developer, Longbow 1 & 2 all Versions
I searched the inet for Infos about Longbow but the NoCD's doesn't Play janes Book and
Movies. So i tried self. At my research with Longbow 1 i discovered a 'CDEMU.ini' in
the Code. This tells me 'CD-Emulation'. Then i had to figure out what in this text file
is available.
The Result: The Header of the Ini says CDEmulate and the Content is CD00[num].
Solution - Create a textfile CDEmu.ini in the Longbow 1 Game Directory.
Snip -----:
[CDEmulate]
CD001=C:\Janes\Longbow1 (<- No backslash at the end)
CD002=C:\Janes\Longbow1
CD003=C:\Janes\Longbow1 (<- only if you have the Gold Version)
Snip -----:
Thats all , copy the last files (Movies, etc.. to the Game Directory)
and voila Longbow 1 plays without erros full from HD. Janes book and Movies are working.
This works with the 3CD Version (adding CD003= in the ini) and with the Anthology/Gold,
3DFX and ... the same technic works with Longbow 2 😁
This info was well hidden in the code. Not even the Process Monitor has notified about
the file is missing.
I think this information is in good hands at the Vogons Forum.
Memory Problem: Longbow 1 all Versions
The Problem with Longbow 1 on Modern Maschines with more as 365,72MB Ram. It's a Memory
bug. LB1 says 'Not enough Memory' 0x000008.
Edit:
I found a Ini command named [Backdoors] with a value HEAP_PERCENT in combination
with GlobalMemoryStatus for the ini CA.ini.
It exists a few GlobalMemoryStatus Messages in:
- LBWin.exe (Only the DirectDraw Version)
- wrap.dle
- tutor.dle
Source of the Memory Bug:
.text:10002DD0 push ebp
.text:10002DD1 mov ebp, esp
.text:10002DD3 sub esp, 6Ch
.text:10002DD6 mov [ebp+Buffer.dwLength], 20h
.text:10002DDD lea eax, [ebp+Buffer]
.text:10002DE0 push eax ; lpBuffer
.text:10002DE1 call ds:GlobalMemoryStatus
.text:10002DE7 push offset FileName ; ".\\ca.ini"
.text:10002DEC push 7 ; nDefault
.text:10002DEE push offset KeyName ; "HEAP_PERCENT" (< Heap Size in Percent?)
.text:10002DF3 push offset AppName ; "Backdoors"
.text:10002DF8 call ds:GetPrivateProfileIntA
.text:10002DFE mov ecx, 0Ah
.text:10002E03 sub edx, edx
.text:10002E05 mov [ebp+var_C], eax
.text:10002E08 mov eax, [ebp+Buffer.dwTotalPhys]
.text:10002E0B imul eax, [ebp+var_C] (Integer Multiply)
.text:10002E0F div ecx
.text:10002E11 push eax ; dwMaximumSize (< Maximum Calculate Crash the game)
.text:10002E12 call sub_10008590
call sub_10008590
.text:10008590 dwMaximumSize = dword ptr 4
.text:10008590
.text:10008590 push esi
.text:10008591 push edi
.text:10008592 mov esi, 0C00000h
.text:10008597 call sub_100085E0
.text:1000859C test eax, eax
.text:1000859E jnz short loc_100085A5
.text:100085A0 xor eax, eax
.text:100085A2 pop edi
.text:100085A3 pop esi
.text:100085A4 retn
If i set dwMaximumSize (Heap_Percent to 0 or 70 in the ini) the game works without Crash.
Other Values e.q. 32, 64 or 80 Crash the Game
Solution - Memory Bug Fix:
Add this to the CA.ini (Gold Version and Anthology 3DFX Version)
Snip -----:
[Backdoors]
HEAP_PERCENT=0
Snip -----:
Add this to the CA.ini (Anthology DirectDraw Version)
Snip -----:
[Backdoors]
HEAP_PERCENT=70
Snip -----:
I have both version Gold and Anthology, both patched to 3DFX and 1.04F and the Executable Files are different
from Gold 1.04F <-> Anthology 1.04F and the 3DFX Version too. The Gold Version has problems with Movies.
Alternate for the Memory Bug you can use 'Thorium's Gamefixer' if the solution not work for you CG Baord for Infos
The Download link is offline. you can get here
Run Longbow 1 with GameFixer "C:\Janes\Longbow1\lbwin.exe" -memoryfix TotalPhys=33554432.
This works, i have 16GB. For 3DFX, put the the nglide.dll's in the game Directory and set the Compatibility to
WinXPSP2.
I have this postet at the Flight SimsHQ Forum too but I think that goes under there.
greetings Marty
Reply 1 of 4, by Gamecollector
IIRC the movies play correctly sometimes if you install the 1.04 patch.
The trouble is - if you install 1.04 + GoldFX patches the game crashes in WinXpSp3.
If you install the GoldFX patch only - the game works ok but w/o movies and with the mouse bug - the doubleclick is too fast.
Reply 2 of 4, by moknok
the longbow gold patch adds 3dfx support gets rid of the apache in historical missions and changes the version to windows 95.
I have played longbow gold and beat both campaigns on dosbox i didn't crash once even watching the movies.
https://www.youtube.com/watch?v=8phIv-NerM0
also lb2
https://www.youtube.com/watch?v=gXiYEflIJxs
| WIN98SE non OEM | PII MMX | 350Mhz | 384RAM | Voodoo3 2000 PCI | DX7 | 126GB+ | Yamaha DS-XG Sound |
Reply 3 of 4, by Marty2dos
How i said, the Gold 3DFX Windows Version is different as the Anthology 3DFX Windows Version. In my Gold 3DFX Windows Version , the Movies are broken, Not in the Antlogoyx 3DFX Windows Version. The Movies works smooth and i Use nGlide with 4k
Reply 4 of 4, by Marty2dos
moknok wrote:
the longbow gold patch adds 3dfx support gets rid of the apache in historical missions and changes the version to windows 95. […]
also lb2
Yes i know. The MS-DOS Versions are not a Problem. The Historical Missions works on the Anthology.
And for LB2 i use nGlide too ,up to 4k 😀
