K6-III+ Rig, Ready for battle :)
Reply 20 of 36, by Stermy57
Hi mamba
I have done some experiments weeks ago.
Win98SE without unofficial pack is the fastest is for my AMD K6-3+ 400@600Mhz
Another point is to find the right graphics card
I think that FX series like FX5700-5900 are inadequate ( for socket 7) bad driver support and in the same time FX mainstream and high end level are to strong
GeForce 3 or GeForce 2 with old driver detonator version under 3x.xx are better
If I were you, I would bought a Northwood or thorougbred-Barton system to run morrowind of course with your Leadtek FX5900! 😀
Reply 21 of 36, by Standard Def Steve
falloutboy wrote:
It was DonPedro AFAIK
Good lord, that's quite a score! When I tried to build an ultimate K6 system years ago (and failed miserably--thanks to the K6-2 500 I was using), I was happy to hit just half of that score with a GeForce3 TI500. Actually, I don't remember if I even cracked 2k...🤣
"A little sign-in here, a touch of WiFi there..."
Reply 22 of 36, by Mamba
I obtained 3400 points with the fx5900xt.
I' try win98se without fancy service packs as soon as possible.
Plus, soon will be here a weird Radeon 9800XT with 128bit... Strange card, it's keyed for 3.3v.
I got 4 other retro (or strange) rigs to play with, but for now I want to pimp this one.
Reply 23 of 36, by shamino
Morrowind is heavily CPU bound, it doesn't care nearly as much about the graphics card.
Back in those days I think I would have been happy to deal with 10-20fps. Nowadays we've gotten used to faster framerates though.
This might not be what you had in mind, but there's a mod for Morrowind called the "Ultimate Morrowind Anti-Mod" which is designed to speed up slower outdoors areas. It removes a bunch of minor objects that the player normally won't notice. I never tried it myself, but my saved copy of the PES page shows a 9.75 rating. Not that that means much - people on that site were always giving 10 ratings for everything.
Reply 24 of 36, by meljor
I tested a LOT of cards on a k6-2 system and in d3d i got the absolute best performance with these cards: voodoo4, voodoo 5 and matrox g400. They were about 5-10% quicker Than ANY nvidia card from TNT2 to gf4 Ti.
This was with 98se, Asus p5a, dx9 and ali agp 1.72.
Reply 25 of 36, by Mamba
NOW it is REALLY ready for battle 😈
Over 4200 3dmark2001SE points
K6-III+ 633MHz (115x5.5)
GA5-AX Rev 5.2 bios F4
512Mbyte RAM PC133 Single stick
Leadtek 5900XT @ 450Mhz/850MHz core/mem GAT2
Promise controller TX2 SATA150
WD Raptor HLFS 74Gbyte
Audigy SB0090
Optimizations via CTU on K6 and Wpcredit on memory
Not bad for a socket 7 😀
Reply 26 of 36, by meljor
nicely done!
Reply 27 of 36, by candle_86
honestly my K6-3 struggles with Starfleet Command Orion Pirates which is alot simpler than morrowwind
Reply 28 of 36, by sliderider
Mamba wrote:
Uhm... Installed Win2000 with SP4. I got abysmall performance with 3DMark2001 (2400 points.... 1000 points less than XP). That's […]
Uhm...
That's weird... Isn't win2000 supposed to be more fast?
I think I'll revert to XP SP3.
Someone at K6plus managed to hit 4000 points with the same 5900xt on a P5A and a K6-III@600Mhz.
Really don't know how...
If you can, you might try XP SP1 instead of SP3.
Reply 29 of 36, by matze79
Even at 690 Mhz OC you will not gain much more FPS...
Upgrade to Slot A 😉
Reply 30 of 36, by Iris030380
Morrowind was notorious for bad performance. I know the visuals were impressive back then, but even on a top rig of the time playing at 1024x786 with high/max draw distance was a lag fest in most even on a Geforce 4Ti with a fast Pentium 4. It simply wasn't very well optimised. Leaks everywhere. Not only that, but the game runs so many calculations for almost every action, making it a very CPU intensive game. A K6-III running Morrowind is insane, and nice work for even gettin 10-25fps from that rig!
Also, the only way to get the nice pixel shaded water in Morrowind was to run it with a card that supported Pixel Shader 1.1 (I believe), such as the Radeon 8500 or higher, or the Geforce 3 or higher. Possibly the Geforce 2 Ultra as well. The MX-440's didn't support Pixel Shader 1.1, so you end up with the standard transparent textured water effect but no pixel shaders.
Installing MGE (Morrowind Graphics Extender) allows for some 3rd party optimisations and actually runs the game faster than the original config does at like for like settings. It also allows for modern machines to run at far higher view distances and with more lighting effects.
If I was going to build a rig specifically to get the most out of (unmodded) Morrowind, while keeping it Retro Style (because honestly, Morrowind tends to eat everything you throw at it) I would suggest something like a fast P4 Extreme Edition or simply a 3.4Ghz Prescott, a gig of DDR-400 and a 5950Ultra / 9800Pro. Thats if you want smooth gameplay at 1024x786 or even 1280x1024. I mean just have some fun and build the dream machine you really wanted to own back on the date Morrowind was released! (Only this time will not cost you a silly amount of money) 🤣
I played the shit out of it the week it came out on my crappy Duron 700 with a Geforce4 440MX and it ran like ass. Not much better than your K6-III rig does, if any. Still dumped 400 hours or more into it though. The great thing was I never even finished it that time round. I played it again a few years back on a C2D with a 1950XTX using the Graphics Extender and finally finished it. One of the best games ever made for sure! 😎
I5-2500K @ 4.0Ghz + R9 290 + 8GB DDR3 1333 :: I3-540 @ 4.2 GHZ + 6870 4GB DDR3 2000 :: E6300 @ 2.7 GHZ + 1950XTX 2GB DDR2 800 :: A64 3700 + 1950PRO AGP 2GB DDR400 :: K63+ @ 550MHZ + V2 SLI 256 PC133:: P200 + MYSTIQUE / 3Dfx 128 PC66
Reply 31 of 36, by Mamba
I am resurrecting this discussion as I would like to do the same with a mvp3 motherboard.
I resurrected a Soltek SL-56G5
https://theretroweb.com/motherboards/s/soltek-sl-56g5
It is a promising motherboard as it lets me boot at 133Mhz FSB with my K6-2+ 570 modded to III+ ( thank you Sphere) and enter Windows (then freezes).
The FSB is floating around though so I think it needs to be recapped.
The problem is, I really do not remember which driver I used for the 5900xt
And which wpcredit optimisations to use on a mvp3 chipset.
I am using interleave enabler and CTU already.
Are they enough?
Reply 32 of 36, by Mamba
I am focusing on ATI gpu this time.
Using a R9250 128bit at the moment, mainly to find stability on the OS (Win98SE).
The catalyst 4.3 make system to crash during 3DMark 2000. Probably I will try omega 4.2
But feel free to suggest alternatives.
This motherboard and chip are extremely promising.
Can’t wait to recap this Soltek.
Reply 33 of 36, by Mamba
Ok update.
My friend recapped the board, even put some tantalium capacitors on key positions….
AGP isn’t working anymore….
Everything is fine but 3D apps just crash.
This on XP.
Funny thing is that it happens with PCI gpus also.
Installed win98SE and from dxdiag I am not able to see 3d acceleration enabled with Nvidia.
With ATI I have no AGP, see attachment.
So I think it is even worse.
Any help?
Tried multiple gpus of course.
Reply 34 of 36, by Mamba
Update.
Was able to make a 9250 work, but still I do not see AGP acceleration enabled on dxdiag.
Run 3dmark2000 and obtained this (k6-III+ 550)
Latest omega drivers for 98.
Not sure it is ok or not.
Reply 35 of 36, by Intel486dx33
I followed Philscomputerlab recommendation on setting up my AMD k6-III@550mhz.
1) install Win98se
2) install SP3 core updates only - reboot
3) install DirectX9 from SP3 update package. - reboot
4) Finished
This made my K6 pretty stable and Reliable.
You can get the files from Philscomputerlab.com website.
Reply 36 of 36, by Mamba
I am going on to troubleshoot my mainboard.
Reinstalled Windows XP, it gives me more flexibility, but kept SP2 and a pair of .net updates (1.1 and 2.0).
I changed the sticks of ram and used two pc133 cas2 instead of cas3 (all kits are from Infineon).
With cas2 sticks it seems far more stable.
I can use both Radeon I have, 9250 and 9500.
But both refuse to work with omegadrivers (3.9 and 7.14) they only work with 6.14 catalyst embedded in WinXP.
Not sure why and I think they are not the fastest ones for those cards (any advice?).
But at least they work.
Can a mismatch or mix in drivers language cause bsod?
Will try nVidia.
