What is printed on the BIOS chips (the two left of the SIMMS, one with a sticker on it with some writing)?
I see an oscillator at the bottom-left of the board - the shiny tin can. What number is printed on that? There's a good chance that it is twice the CPU's speed (ie if it says 66 mhz, then it needs a 33 mhz CPU).
You are lucky the infernal battery was removed or never installed (next to the keyboard connector). They ALWAYS leak and damage the board. It will lose its CMOS settings without some type of battery, but not a big deal unless you are going to use it often.
