First post, by jesolo
I'm looking at buying another 16-bit VGA graphics card for one of my older 386 motherboards.
I wanted to get some input on what would be the best buy, based on the list below of 16-bit VGA graphics cards that are currently for sale:
  1. OAK Technologies with OTI087 chipset (appears to either have 256 KB or 512 KB RAM, non upgradeable)
  2. OAK Technologies with OTI037C chipset (only has 256KB RAM on board, non upgradeable)
  3. Trident with TVGA8900D chipset
  4. Trident with TVGA9000i-1 chipset
  5. Trident with TVGA9000i-3 chipset
  6. Unknown card with CHIPS F82C451 C chipset
  7. Appears to be a Pine Technologies PT-5408 card with a Realtek RTG31030 chipset
  8. Appears to be a Pine Technologies PT-507A card with a Realtek RTG3106 chipset
  9. Unknown card with a Realtek RTG3105E chipset
  10. Unknown card with a Realtek RTG3105i chipset
  11. Unknown card with an MX86000FC chipset (has 256 KB RAM onboard, non upgradeable)
  12. Unknown card with a Cirrus Logic CL-GD5401-42QC-B chipset (memory non upgradeable)
  13. Unknown card with HMC HM86305 chipset (empty memory sockets that can be upgraded)
  14. Unknown card with Paradise PVGA1A-JK chipset
Reply 1 of 19, by PhilsComputerLab
Just some general impressions.
OAK are graphics decelerators. Great if a game runs to fast 😀
Cirruc Logic are very good all rounders. Fast, cheap, simple. Trident I believe is in the middle of the pack. The other card I don't know. My best cards I have are ET4000 and WD chip cards.
Reply 2 of 19, by darksheer
You can't go wrong with Cirrus Logic cards : fast, good image quality and compatibility.
Reply 3 of 19, by PhilsComputerLab
Yea I'm using a CL whenever I play around with 386 gear. One cool thing is that, compared to other cards, the image stays centred when you go from command line to 320 x 200 games. The other cards always need readjusting on the monitor / scaler.
I remember a LOT of computers, even later VL machines, had CL cards.
Reply 5 of 19, by Scali
Trident, Realtek and Oak are all notoriously slow cards.
The Cirrus Logic is probably the best card in that list.
The Paradise might also be okay, although I believe that is a very early chipset, mainly designed for 8-bit systems.
I don't know the other cards.
Reply 6 of 19, by darksheer
dondiego wrote:
The Trident 8900D is the best by far.
Nope, it has blurry output and would probably perform slower than an OAK OTI087...
I don't know how well perform a CL-5401 vs an OAK OTI087 but that would definitely be the most reliable cards of the chart.
Reply 7 of 19, by HighTreason
That Paradise chip is the one used in the Toshiba T3200SX I think, it is acceptable for a 16MHz 386, Crystal Dream is watchable (though the music goes out of sync, interestingly I think Triton anticipated that however) but it gets its ass handed to it by the Cirrus 510/520 in the Zenith SlimsPort 286 really. The Cirrus in that list would even be fine in a slower 486 system i think (Like an ISA DX-40).
To cut a long story short, out of that lot, pick the Cirrus unless you have a slower 386SX, in which case the Paradise will be fine if the price is right.
Reply 8 of 19, by dondiego
That trident is a late isa card, output quality depends on individual samples. I believe that cirrus is an ancient rebranded acumos. Other chips are ancient as well. Oak, realtek and hmc=utter crap.
Eliandas ISA VGA card roundup
LZDoom, ZDoom32, ZDoom LE
RUDE (Doom)
Romero's Heresy II (Heretic)
Reply 9 of 19, by darksheer
Ok I should have said it first : I own an ISA Trident TVGA8900D loaded with 1024 KB RAM at 70 NS jumpered to work at 16 bits and 0 WS and an ISA OAK OTI077 with also 1024 KB RAM at 70 NS. I tested both on a DX2-66 with fastest bios settings and tweaks => OAK card had better image quality and was 2.5 fps faster than the Trident in DooM. Then an ISA CL-5422 512 KB 70 NS was 5 fps faster than the OAK and only 0.2 fps faster than an TSENG LABS ET4000AX with 512 KB at 80 NS.
I don't think the trident is defective and as Tseng Labs with its ET4000AX, I think the manufacturer really matter in the final product speed.
But still, I would not recommend them over Cirrus Logic.
Reply 10 of 19, by brostenen
I ran ET4000 ISA when I had a Cyrix 80486 SLC and CL-5428-VLBus when I had an 80486dx2 back in the early 90's
Both cards were great for the systems I had back then.
Reply 11 of 19, by leileilol
jesolo wrote:
[*]Unknown card with a Realtek RTG3105E chipset
[*]Unknown card with a Realtek RTG3105i chipset
Steer clear of these ones. 😵
Reply 12 of 19, by Formulator
Diamond Flower VG-7000 256KB max 512KB (OTI067), I have seen for sale.
I use TVGA8800CS on 286 which works great.
I also have Diamond Speedstar Rev. 4 512KB (TSENG ET4000AX) upgraded to 1MB which would work well on a 386.
Reply 13 of 19, by kixs
I'd test different 512 and 1024kb cards to see which one is the best for your configuration.
It's somehow funny with Trident cards. They are usually slow and some can even have bad quality output. But I have one 8900D 1MB that performs as fast as ET4000 and has good image quality. It seems rare but there it is 😉
I even noticed that although the CPU is slow, like 286, there is some performance increase with good VGA card (like ET4000). Tested with 3Dbench v1.0 it went from 6.4 to 7.1 when replaced some slow Trident with ET4000 - I didn't think it would be any faster or at least noticeable faster on such a slow system.
Any card can have bad/good quality image output as these cards are 20+ years old... and some electronic components can get out of shape and make cards perform worse. I've seen cards from Cirrus Logic, S3, Tseng and Trident that had somehow blurry image.
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 14 of 19, by robbo007
Why is the OAK oti087 so bad? I just located one for 10$. hahaha going to test it in my IBM AT.
Reply 15 of 19, by ATauenis
It may have a stripped-down RAMDAC. My TVGA9000i-3 cannot work in 800x600x256 with LCD monitors as it uses interlaced scan (however, 800x600x16 colours is working perfectly with normal progressive scan).
2×8080, 2×Soviet ZX-Speccy, 1×MacIIsi, 1×086, 1×286, 3×386DX, 1×386SX, 2×486, 1×P54C, 8×P55C, 7×Slot1, 5×S370, 1×SlotA, 2×S462, ∞×Modern.
Reply 16 of 19, by .legaCy
I have one Trident TVGA 8900D that i got for cheap just for testing, but from what i was told, this board would slow down even a 386, which makes sense, i got mine from a lot of parts from a junk 286 machine(mobo was in a terrible shape, however the expansion cards were good, the mobo i dessoldered all the 74 series logic ic's, so it was pretty nice).
Reply 17 of 19, by tayyare
I know they are slow, but they have other very nice vitues. This card can run in both 16 and 8 bit ISA slots, and look at what range of monitors it can support:
http://stason.org/TULARC/pc/graphics-cards/C- … -XVGA-VG-7.html
It can emulate EGA, CGA, MDA (with switches, not TSRs) and use their monitors, too. That's a very good thing if not unique.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 18 of 19, by lvader
No the D version is quite a fast card.
Reply 19 of 19, by Ozzuneoj
Wow, this is a really old thread.
Anyway, I do remember reading that the Trident 8900D is usually a good, fast ISA card. I have one but it blew a tantalum when I tried to test it, so it's awaiting repairs before I can test it myself. 😀
