Advice on building an Windows XP 32-bit system
First post, by Robin4
I really would some advice on a Windows XP system to build.. What i like if it would be a little bit period correct.. For the graphics card it may be some faster card out there.. I really want to play my games just smooth..
In the beginning i had some older ideas that might could work, like make an dual boot system with windows 98se and windows XP.. But that idea i have just put over board, because these two OS combined on one system is just really a pain in the ass.. Like problems with the size of the memory, problem with trying to find the right drivers for windows 98se.. Also i really dont know if stick with the AGP bus would be a great idea, because this is just the limited factor for using faster graphic cards..
My main problem is that i cant decide which hardware i would want to use.. I have got this so far:
3x Msi Neo 2 platinum (n-force3) motherboard S939 *this was my first choice / selection i wanted to use for an Windows XP build and going for an AGP 6800GT or 7800GS OC (also have an Sapphire 3850 AGP here but that one is very noisy on the cooler that i dont want to use.. Also finding the right N-force 3 chipset drivers for windows vista is already a no go. (i know there is one beta package that would work, and no other alternitives
My other idea is the go for an N-force 4 motherboard S939 with pcie ofcourse (i have here an ASUS A8N-SLI Deluxe for this option)
I think that n-force 4 chipset drivers is more compatible with windows vista.. (but it could be a problem as well)
I have also one MSI 790FX-GD70 laying around with an AMD Phenom II X4 955 BE ( from my opinion, this hardware is a little bit to good for what i really want to achieve.
My fourth option would be an asus p5q3 deluxe wifi-ap@n with an Quad core QX9650 ( what i really dont like on this one, is that its almost the lasted windows xp set to get)
I was more thinking to go the S939 way instead. Also because AMD was in shape in that period.
Iam not intended to play the latest period windows xp games if they really work fine under windows 7 as well (mostly i will use this system for Windows XP games only or it they would windows vista.
I really like if i can use Steam on that system as well of maybe using some games from GOG.com to install. I also really like if it could be possible to play multiplayer games on the internet as well.
Iam not intended that i would use this system for browsing or doing bank tasks on it (i do these things on my main gaming pc)
Besides i have also a newer system next to this one which would only running windows 7 32-bit on it. So games that running just fine under 7 would installed there.
My intention is not going for the fastest out there ( i build this system only for playing windows xp purpose, iam not really a speed freak, that whating the most speed out of there system. Nostalgia is also a real important thing for me.. The system just needs to give you that feeling so that the experience also counts.
Maybe i think to install it again in a dual boot, i consider it doing a combination with windows vista Ultimate i have laying here.
Only what is the best security possible when wanting to using this system for multiplayer / online / steam as well.. Which configuration of OS suit for my needs?
Reply 1 of 22, by PhilsComputerLab
Nice plan!
What graphics resolution will you be playing at?
And what games? Maybe list a few...
I found that at 1920 x 1080 resolution, you quickly need a beastly graphics card, which rules out AGP platform straight away. Something around a GeForce 8 or 9 should work well.
I've had good experiences with nForce 4. Very stable, solid SATA controller, no complaints.
YouTube, Facebook, Website
Reply 2 of 22, by Robin4
Which resolution i dont know yet. I think that back in the days i used 1024x768 regular.. I really dont know if switching to 1920 x 1080 would be a good idea in the first place, because maybe some games could get in trouble i think.. Because 1920 x 1080 wasnt the native resolution back then. But iam also think to go that way around GeForce 8 or 9, and or maybe one or two series later perhaps if i see that it would needed.
I think that to downside of the earlier board would be the older previous versions of pci-express (like version 1.0 and 1.1) I think it would probably recommend to get a pci-express 2.0 board instead. I really like to hook up a nice SATA III pci-e x4 controller to get some faster storage / controller going.. SATA II would just nice to hook up some older harddisk, but for connecting an SSD i would definitive go for using an Sata III controller instead.
Also you said in the farcry topic, when max out on resolution, that you recommended to go for a later motherboard with faster cpu (cpu would be bottlenecked). So i think about that too as well.
Most games i really want to play where from the windows xp period (thats why i going make this system) I cant give you the whole list of games i want to play, because i dont have one here. But when i think on, that i want to go play; Half-life 2, farming simulator 2011 perhaps if it could, return to castle of wolfen stein, battlefield 2, Call of duty II, serious sam I, II, III, simcity 4, Quake 4, Doom III, Farcry 1, Older GTAs, and more..
Maybe it could that i mentioned some game pre 2009, but those i have an other older system here where i want to run this games on.. I really have to see if its needed Windows XP or windows vista or windows 7.
I might try a run on the n-force 4 board to try it out, but iam affraid that pci-express 1.1 would be the disappointment if i want to have some seriouser controller in this system.
Reply 3 of 22, by tayyare
Before suggesting anything let me tell you my XP experiences first. My first XP box was an AMD socket 754 with Asus K8N-E deluxe board, 3200+ CPU, 2GB RAM, a GeForce 6800 256Mb display card and other necessary trivia. It goes like that till mid 2009 when I built something new (Core2 quad 9550, Asus P5Q Premium, 4GB RAM, Asus GTS250 512MB display card). I'm still using this machine with slight upgrades (a BD RW drive, an Asus GTX 560 Ti, bigger HDDs, etc.) and until the summer of 2013, it was also an XP machine.
The first machine I told you, have been relegated to "secondary/backup" PC status, and also it is still something I use, and my only XP box, (after updating the C2Q to Windows 7 in 2013). But not like the newer rig, I continuously updated this older one, with the second hand parts I found.
- Display card downgraded to FX6200 after FX6800 blown
- CPU upgraded to 3700+
- RAM upgraded to 3GB (board max)
- Display card upgraded to first a 512 MB HD3650, than a 1GB HD3650
- Motherboard upgraded to Asus K8N4-E Deluxe and display card upgraded to Geforce GTS 250 1GB
- Motherboard upgraded to Asus A8N-SLI Premium, RAM to 4GB, and CPU to X2 3800+
So, based on the experience I had, my suggestion to you:
- If you want an XP beast, which can churn out anything you will throw at it, then go for the newest hardware having still XP support/drivers. I mean not even Core2 Quad, Phenom II, but much newer. To say the truth, I really don't see the point with this one. Such a machine can be considered as "daily rig", can run Windows 7 easily and happily, and can play all titles even the modern ones with ease (providing a good display card is also on board).
- If you want a bit of nostalgia and excitement, I suggest socket 939 is way to go. The board you mentioned, A8N-SLI is a very solid one. For display, when I also asked the same question here sometime ago, mentioning that I'm a nvidia guy and like some sort of overkill, people suggested something with Nvidia G92 (8800, 9600, 9800, GTS250, etc.) and I'm actually very pleased with my current GTS250.
To say the truth, I don't consider an XP gaming machine as a practical thing. I'm not a deep core player, but had no experiences of any games yet which runs in XP but not in Windows 7, especially none of my Steam or GOG titles (250+ in total). This certainly includes Half-life 2, Return to Castle of Wolfenstein, Call of Duty II, Serious Sam, Simcity 4, Doom III, and Farcry. If any of my games can played in my Windows 7 machine, then I choose to do just that. My XP rig is just a nostalgic side project for me, not a video game platform.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 4 of 22, by Robin4
Is there anyone who can give me more advice on which OS to install.. i have both windows xp as windows vista here.. I know that windows vista is saver to use..
Reply 5 of 22, by PhilsComputerLab
Solid advice tayyare!
AFAIK Intel goes up to S1155, AMD FX990 gear also still supported.
Reply 6 of 22, by Triton
Well Windows OSes generally come in two sorts, the DOS type (Windows 98, Windows ME and earlier), and the NT type (Windows 2000, Windows XP, and later). Older games only play nicely with the former, and newer games only play nicely with the latter. And games that were created during that transitional period between the two types play nicely with both. What I mean by play nicely, is natively, without the need for any crazy workarounds.
So it really depends, on what end do you want the flexibility to lie? There's always dual-booting though.
Reply 7 of 22, by Skyscraper
I would build a socket 939 system running a single G92 Geforce 8800GTS 512. You dont build a system like this for the software it lets you run, you build it so you can tinker with it!
Reply 8 of 22, by meljor
My advise has always been: for windows vista or higher the minimum is a dualcore machine with 2gb ram. What this means by my standard is: anything lower is a windows xp machine.
I like to use barton athlon xp cpu's (and geforce 6/7) for xp since it is what i used the most back then. Athlon64 and geforce 8800 or higher is beast.
Reply 9 of 22, by Robin4
My concerns is more about get this system secure to use on the internet.(muliplayer games as task)(maybe there is still a battlefield II server online) As i said earlier iam not intended to make this my regular main pc, also i wont doing bank accounting or 100% websurfing..
The main task would be to run windows xp games on it, but on the secure way.. So i can use it for multiplayer also.. Like to install steam and using GOG.com games..
About the hardware i really dont care much if i cant do anything with first period hardware. Because an n-force 4 doesnt not have much pci-express slot.. For more newer games i always can user a better system for it.
If i would use the system only for offline, the best way would be just install an installation of windows xp.. (so security dont bother me much)
But i want to use this system for offline and online.. I really dont save any important information on it.. But i really like to get hacked..
I really like to know, if i would install 8GB of memory (for virtualizing) and would install an 32-bit version of vista, i know that the system only would see 4GB of memory.. Would it be possible if i install virtualizing software that i can allocate the remainder of the other 4GB of memory?
Reply 10 of 22, by Jorpho
Why don't you find out what games still have an online presence, and then decide what you need? Any game that still requires an XP machine with a particular configuration in order to be played is likely to have a very, very small online community.
No, virtualization does not work that way. Also, it would be more like 3.5 GB of memory.
Reply 11 of 22, by tayyare
Nicely worded!..🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 12 of 22, by tayyare
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 13 of 22, by GeorgeMan
Try running an updated installation of XP SP3 with a current browser and other software on a lowy s754 Athlon 64 with 512-768MB RAM. It'll be far from beast, on the "barely acceptable" side of things. 🤣
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 14 of 22, by tayyare
I completely agree with that. My previous XP setup (just upgraded to 939 dual core 3800+, 4GB) was a socket 754 3700+ with 3GB of RAM and fully updated XP SP3, and it was only "acceptable as a occasional spare PC" when it comes to daily jobs (MS office, internet, ACDsee/Paintshop Pro, etc.) And I'm comparing it only to a 2009 core2 duo system, not any new fancy systems. Today, I never think ANY generally usable XP system would be ok with less than a couple of GBs RAM.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 15 of 22, by Robin4
I dont think if you want to play farcry on higher settings, it could cope with these slower processors.
It is nice to have a nforce 4 system, but there are some limitations on.
Reply 16 of 22, by PhilsComputerLab
One issue with XP gaming is that many PC milestone games from that era, ran fine on a typical 17" or 19" monitor. But playing at 1600 x 1200 or Full HD, the cards from that era are quickly reaching their limits. Benchmarks is fine, but if you actually play Doom 3, Far Cry, FEAR and reach some of the more taxing levels, the situation changes a bit 😀
Something else you will find is performance with two cores. I read a few launch reviews, and the usual message is that two cores does bugger all. But when I did a few tests, I found these games benefit greatly from a second core. The hardware, or software, simply didn't show this.
I find a 7900 GTX simply not up to the task. A 8800GT and one of it's many offspring does much better. I believe the GTS 250 1GB is the last / best card like that. Been chasing a cheap one for a while...
They are old enough to support period correctish drivers and reasonibly easy to obtain. For value gamers, the 9600GT is great. Not far behind the 8800GT, which surprised me a bit. It's more powerful than I thought.
The later cards like the 8800GTX 512, 9800GTX, 9800GTX+ all had much better coolers.
I don't know about the 400 series. I've got an old 460 768MB, but never done anything with XP (yet).
Reply 17 of 22, by Skyscraper
If you are worried about performance at 1920x1200 with AA and stuff get a Geforce GTX 285, its the fastest of the Tesla cards but a GTS 250 1GB as Phil suggests should be enough.
CPU wise even a single core Socket-939 CPU like the Athlon 64 4000+ 2.4 GHZ should be enough for any XP-era game.
Reply 18 of 22, by PhilsComputerLab
285? Nice, will keep it in the back of my mind in case something pops up.
Regarding the processor, I've done a bit of testing, but not enough to make up my mind / publish something. But my gut would want something faster than that 😵
Reply 19 of 22, by Skyscraper
Well its always nice to have some headroom 😀. The FX 57 and FX 60 is expensive though so if going for Socket-939 a better option is making sure the CPU your buying is a San Diego core and overclock it to 2.8 GHz which 90+% of the San Diegos can do without increasing the voltage, at least the higher bins. The dual cores have some timing issues (that never bothered me) so its perhaps best to avoid those.
The Geforce GTX 285 is nice as it isnt as power hungry as the GTX 280 and performs even better! It needs more power than a GTS 250 though.
