First post, by keropi
- l33t++
Hiya fellow VOGONers 😊
I recently upgraded the cpu in my main build , from a p1 200mmx cpu I went to the 233mhz mmx model.
Everything else is the same in the build, nothing changed except the cpu + heatsink-fan and the psu (using the recapped heroichi 300W psu from this thread: 300W Heroichi PSU: worth refurbishing?)
My concern is that while the 200mhz part was cool the 233mhz is noticeably hotter (according to intel 200mmx has a 15.7W TDP and 233mmx a 17W TP).
The heatsink is too warm to the touch and I am pretty sure I had a thermal shutdown in 98SE after ~1.5hrs while the machine was streaming mp3 via winamp.
I am currently using this heatsink:
Maybe it's too small?
There is a arctic silver ceramique paste between the cpu+heatsink and the only way I can keep it cool is by using a 60x60x20mm 3500rpm fan (original evercool is a 50x50x10 one that in all honesty isn't that good in airflow as I just found).
I also jumpered the vcore setting from AUTO to manual 2.8v just in case the mobo was overvolting the cpu but things remained the same so it's not that.
The system is stable - no weird crashes or errors - until a thermal shutdown that is... once that occurs I need to wait for the cpu to cool and then the system powers up again.
Anyone has any idea wth is wrong?
Is the heatsink too small ? (didn't intel bundle some crappy little heatsink with pentiums?)
Is it a cpu thing? (revision or they are just hot)
Could it be a psu issue? Voltages seem OK though and things run OK
I must add that it's summer here and the ambient temperature is high but never more than 30 degrees celcius (86F) where the pc is... shouldn't really matter for a p1 IMHO though.
Any insight on the matter will be greatly appreciated before I start replacing parts 🤣
TIA!
