help me out im new here
First post, by aLinux
hello
my name is Alin.. my friends call me aLinux
yesterday ive made a gaming rig work and now im stuck with it,i reinstalled 98se ,more than 10 times
i have the shutdown bug. its stuck there !
after clean install shut down works perfect. after i installed all drivers it was stuck again
i got another win98 se cd i installed it.. installed all drivers..shutdown worked,after i installed opera.. again 🙁
i tried to update to unofficial service pack.. the shutdown patch from microsoft and so many tweaks,but the same result,stuck there
all drivers i used ar for windows 98se
i want to fix it somehow,right now im doing a clean install again ! 🙁
tested ram and hdd and they are perfect. it runs xp or other os very good
system specs
Model:Hp Compaq d530c
Processor: Intel Pentium 4 2.66 Ghz
Ram: 1 Gb ddr 400
Hdd: 40 Gb IDE
Video: Nvidia GeForce 4 64 mb AGP 8X (used latest driver from nvidia webside)
Sound: SoundMax (latest driver from hp website)
Network: Broadcom NetXtreme BCM5782 (an older version of driver from hp website)
Reply 1 of 8, by Stojke
Whats the problem with shutdown? Describe it more.
Reply 2 of 8, by meljor
1gb can give trouble in 98se, don't know if it gives problems when shutting system off, but 98se needs some tweaks to work right with 512mb+
Reply 4 of 8, by pewpewpew
In my experience a disconnected ethernet card can cause a shutdown hang in 98se regardless of patches. You can check if this might be your issue by simply removing the card.
If everything else is fine, then I recommend you stop fighting it -- accept it as part of 98's character. (I like 98se. But it does have a lot of character.)
EDIT: Yes, that's too much RAM, though yes it's unrelated. Scale it back to 512MB. If you are doing something that requires more, then you're doing something that requires XP.
EDIT 2: While we're at it, the latest drivers for an older Nvidia card are often not the best choice. Use google to search this forum via 'site:www.vogons.org' for threads discussing the best drivers for your card and 98.
Reply 5 of 8, by aLinux
Beegle wrote:
The PC gets stuck on the windows is shutting down message, and then the PC never shuts down?
yes its stuck on windows is shutting down
ok ill try with 512 ram and older video driver
and the ethernet is connected (onboard)
ok i tested it,installed soundcard,ethernet,opera.. all good restarted ONCE then.. stuck again
what OS should i use for old games on this machine ?
if 98 fails.. what else ?
Reply 6 of 8, by jesolo
Refer to this link as it contains a patch that might address your problem (Windows 98 Second Edition Shutdown Supplement): https://support.microsoft.com/en-us/kb/239887
I've attached the file (004756us8.exe).
You also might want to install the IDE Hard Drive Cache Package (https://support.microsoft.com/en-us/kb/273017). File also attached.
Alternatively, download and install the Unofficial Windows 98SE Service Pack 2.1a.
It contains a number of Microsoft patches/fixes that should address most of the issues you're likely to experience.
You only need to install the main updates (the rest are optional).
Reply 7 of 8, by tayyare
I now its annoying but I also know its not deadly. When you stuck with "Windows shutting down...blah..." window, just wait for a couple of minutes and shut down your computer. Nothing bad will happen. I had many rigs that do that to me, and even during the days, when you make one last update or install that one last utility, this was happening sooner or later. The matter was not if, but when. We used 98 machines like this forever at that times without anything bad happening.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 8 of 8, by pewpewpew
Exactly. It's part of living with 98.
"old games" is not nearly specific enough.
If you mean old Windows games in general, then your hardware looks fine for an XP machine, and as a rule of thumb XP will run all the Windows games that 98SE does, except for some from the DirectX7 era. Although I don't like using XP as much as 98SE, it's more stable, and can handle more RAM and newer video cards. It's more like an improved 98, rather than a new incompatible OS. (Tip: for a gamebox, use Service Pack 2 but not Service Pack 3)
Use W98 on older hardware when and if you specifically want a box for DirectX7 games. It'll also make a pretty decent DOS box. But there again, with DOS and some games you may need to go to earlier hardware yet again. OR just run DOSBox, which is what VOGONS was actually about in the first place...
