First post, by SumGuy
Smartdrv.exe isin't loading because it claims there is no XMS memory available to it.
My config.sys is:
DEVICE=C:\DOS\HIMEM.SYS /verbose
DEVICE=C:\DOS\EMM386.EXE NOEMS VERBOSE
DOS=HIGH,UMB,NOAUTO
BUFFERSHIGH=50,0
FILESHIGH=50
STACKSHIGH=32,512
SWITCHES /F /W
BREAK=ON
Autoexec.bat is:
LH C:\DOS\SMARTDRV.EXE A- B- C+ /V 4096 4096 /E:8192 /B:8192
This is DOS 7.1 (the DOS that came with win-98se).
I've tried reducing config.sys by removing:
BUFFERSHIGH=50,0
FILESHIGH=50
STACKSHIGH=32,512
but smartdrive still doesn't load. The mem command seems to show that DOS doesn't understand how much XMS ram there is, or doesn't know how to use it. I don't want to pull any ram out of the system to get this to work. What other tricks can I try?
Reply 1 of 6, by PhilsComputerLab
What is this for?
Have you tried FreeDOS? Modern drives have generous caches now 😀 So you might net even need it.
Reply 2 of 6, by SumGuy
I've created a 50 gb FAT32 partition (with 4kb cluster size) on a 2.5" 500 gb SATA hard drive and made it bootable and copied all the DOS 7.1 files to it. I've also copied XP-SP3 and Windows 7 installation CD's to this partition. This is in preparation for installing XP (and maybe win-7 in the future). The drive (once I detach it from my win-98 desktop PC) will reside in a Zotac ID18 mini-PC for use as a livingroom media / internet access computer (this will replace a more noisy and heat-producting IBM thinkcenter).
After re-installing the drive into the Zotac and booting into dos, I started the XP installation (onto the FAT32 partition, because I detest NTFS but need only for large media file storage beyond 4 gb file-size). XP mentioned something about smartdrive not being loaded and suggested that the install would go faster with smartdrive running. I didn't notice that smartdrive hadn't loaded during DOS bootup.
I will probably go ahead and do the install without smartdrive if this too cumbersome an issue to solve.
Reply 4 of 6, by Gamecollector
IIRC DOS 7.1 mem.exe can't display 1 GiB or more XMS/EMS size. It replaces all such entries with "?". But you still have proper XMS/EMS size. You can use FreeDOS version to check.
Smartdrive may fail because CD-ROM driver uses first XMS area for buffering (as the example - uide.sys).
Reply 5 of 6, by Stiletto
Moved to Marvin.
do the Fandango!" - Queen
Stiletto
Reply 6 of 6, by alexanrs
You can try replacing SmartDrive with UIDE. It is an UDMA driver which is also a CD driver and does its own caching.
