Making a batch file
First post, by JubJub
I have XP and I want to make a batch file that will automaticall type in all the "mount c c:\" and such commands. My problem is this, i can't figure out how to make the batch file type the commands into dosbox rather than the command prompt window. I have Dosbox-0.61 as well as dosbox-0.62 so go from there.
Reply 1 of 10, by robertmo
just edit dosbox.conf and type all the mounting under [autoexec]
Reply 2 of 10, by JubJub
All right, thanks. I got that working and I have another question: How do you make DOSBOX execute a command on exit from a program?
What I want to happen is, when I exit the program that I'm running in DOSBOX, then DOSBOX automatically changes directories. How can I do that?
Reply 3 of 10, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
You can run normal BAT files in DOSBOX (as in normal DOS). The BAT file can mount a disk/start program/change the directory etc. As in normal DOS.
Mirek
Reply 4 of 10, by JubJub
Yeah, But I want DOSBOX to change the Directory AFTER EXITING the program. Will that still do it?
Reply 5 of 10, by icemann
Thats more of a matter of dos batch file programming than what to do in dosbox.
Two stones, two crosses, the rest is just icing. - 7th Guest
Reply 6 of 10, by JubJub
Yes well the title of the thread IS
Making a batch file
Reply 7 of 10, by Guest
You would have to make a batch file for every single progam you want to run, or if you're really feeling advanced, there is a way to pass a batch file variables, I sure don't remember how though... as for doing it per program, i'd do something like this for say, Quest for glory 1
scidhuv
cd\dosbox\games\crap
cls
that will run scidhuv.exe, the games executable, then once that executable closes it will change to the dosbox\games\crap directory, then finally it will clear the screen.
Reply 8 of 10, by JubJub
I have a bacth file for my one game
cd\arena
arena.bat
cd\
Now, if i just type in "cd\" then it returns me to the "c:\" prompt. But If I run the batch file, it stays in the ARENA folder.
I have another batch for another game
cd\dagger set dos4gvm=@dagger.vmc fall.exe z.cfg cd\ […]
cd\dagger
fall.exe z.cfg
cd\
And it works fine. It does what I want it to, it returns me to the dos prompt upon exit of the game.
Any help?
Reply 9 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
the first one replace the line
arena.bat with
call arena.bat
Water flows down the stream
Reply 10 of 10, by JubJub
Perfect!
Thanks!
