Reply 8680 of 59175, by HighTreason
sf78 wrote:
Last piece of the puzzle arrived from Japan (CM-32). Now the tower is complete. I blame Phil (as usual) for all this.
keropi wrote:
excellent tower 😁
*vomits*
The attachment vlcsnap-2015-08-14-16h15m52s727.png is no longer available
Had an SC-55, SC-88 Pro, E-MU Proteus 2000 and MT-32 over time, but they all ended up going to landfill long ago starting with the SC-88 around 10 years ago. I don't miss them. SCC-1 and AWE64 Gold are soon retiring too, the AWE will probably find a new home, the SCC-1 will likely just be left behind in the house when I move as I have no use for it and it is defective (Or Roland lied on the box - neither is unlikely)... Maybe I should auction it off just because I have the box and everything, but meh, can't be bothered. Seems there's plenty of nutters out there preserving them so it doesn't matter anyway.
Nah, man, it's always nice when you get the stuff you want. 😉
Reply 8681 of 59175, by sf78
It's not so much wanting as needing. Hell, I wish someone would one day say: "Buy Roland XX, it covers everything from 1985 to 1995 and only costs fiddy bucks". 🤣
Reply 8682 of 59175, by QBiN
CM-500 + MPU-401 compatible interface comes close. CM-32L + SC-55 is probably as ideal you can get for MIDI in that time period.
Phil's Mega Roland Tutorial covers the topic better than any other single source I've seen.
Though, getting close to $50 bux would be a challenge unless you're willing to wait for a couple of once-in-a-blue-moon steals.
Reply 8683 of 59175, by keropi
got some diskette boxes , brand new
...and put them to good use immediately 🤣
Reply 8684 of 59175, by King_Corduroy
Pulled this Futaba MX switch mechanical keyboard out of the garbage today, so far I'm up to three mechanical keyboards rescued from an early death. Let's hope my luck continues! 🤣
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 8685 of 59175, by sf78
You also NEED the first model MT-32 for the late 80's, there's really no way around it. So it's still 3 different units no matter how you look at it. 😀
Reply 8686 of 59175, by QBiN
Meh... Depends if you're play much Sierra or not. I was always more of a Lucasarts fan. Though I have an MT-32 old, it was never a factor for me personally.
Reply 8687 of 59175, by RacoonRider
Never had a single module. Does that mean that I don't have fun? 😀
Reply 8688 of 59175, by PhilsComputerLab
The CM-32L or LAPC-I would be my recommended unit to go for if you just want a single unit, but compatibility with a wide range of games. Missing sound effects is worse than sound effects that sound off 😀
But it's harder to find and likely costs a lot more. The MT-32 (Old) is indeed great to have for many Sierra and Dynamix games, but also much easier to find and cheaper.
The main issue is that there is no real substitute / alternative to these units when you select Roland sound option in these old games. Contrast that with Sound Blaster / FM, which you can choose from a vast range of alternatives. My "MT-32 for $50" project is really the only cheap / free alternative that I know about. It's basically attaching a second PC running Munt and SoundFonts. Anything "MT-32 compatible" works with the default instruments only. While there are a few games that are compatible, like Monkey Island, it's a small list.
Now with General MIDI there are lots of options, with Yamaha being highly popular, or experimenting with SoundFonts.
YouTube, Facebook, Website
Reply 8689 of 59175, by PeterLI
In the US MT-32s are many and cheap all year round. With SoftMPU that puts most of the Sierra titles in reach.
SC-7 is cheap and excellent. Most games do not go beyond GM anyway.
Reply 8690 of 59175, by carlostex
The SC-7 is lame when compared to other GM devices in the same price range. But if someone only wants GM for games well... yeah but get it cheap. At this point in my life i wouldn't pay 20GBP for one, let alone the insane prices some are listed on eBay.
Reply 8691 of 59175, by HighTreason
It's like The "Microsoft Synthesizer" in a box. Makes you wonder if it might not be cheaper to just hook a MIDI cable up to your newer machine and feed the MIDI through that, or a SoundFont.
Reply 8692 of 59175, by brostenen
Too many modules and too many games that need the correct module out of many.
I guess I will pass on midi modules. Though midi music is 100% totally awesome.
(in PC games, prefer metal on my stereo)
Reply 8693 of 59175, by PhilsComputerLab
Here is the video of the project I mentioned earlier: Roland MT-32 CM-32L and General MIDI for $50
The main expense, apart from a spare computer, is a decent USB MIDI interface. Any decent brand should work, but for me a cheap eBay adapter didn't work.
It lets you configure Munt as MT-32 or CM-32L and Bassmidi / VirtualMIDISynth with whatever SoundFont you like. I really the Arancho SoundFont in Doom for example.
Just hook it up to your MIDI interface on your DOS PC and off you go.
Reply 8694 of 59175, by soviet conscript
This months haul from the local monthly electronics swap meet. not to much but there weren't many people at all seeing as the temp was so damn high. cleaning tape and some Sony demo tape on Beta, a AT to Ps/2 adapter in the packaging a VGA card heatsink/fan, some random p4 motherboard and finally the jewel in the haul a Intel l440gx+ duel slot 1 motherboard. all for a total of $7.50. the duel slot 1 was only $1.50.
Reply 8695 of 59175, by meljor
NICE!
Reply 8696 of 59175, by soviet conscript
anyone know what that second power connector is for next to the regular AT connector on the duel slot board? on the Intel product specs sheet images there's no connector there just solder points.
Reply 8697 of 59175, by ODwilly
The AT style connector is called an Auxiliary connector and the weird 10 pin connector I am unsure of what it is called, but I have seen on a lot of server motherboards and power supplies. I will do a little research on that and get back to ya unless someone else beats me to it 😀
Reply 8698 of 59175, by alexanrs
That server MoBo looks SWEET
Reply 8699 of 59175, by kithylin
It looks like standard ATX power connector and a 8-pin EPS-12V CPU Power connector beside that. The bladed "Half AT" power plug is weird though, not many power supplies today have that, you'll be looking for an older power supply there.
