First post, by lolman8776
If I try to mount it with imgmount, it says "Cannot create drive from file".
If I just boot it, OR boot it from the mount it will say "Error loading operating system".
Help plx?
Help plx?
bump
you can't.
Use a different program.
Water flows down the stream
wrote:you can't.
Whats another dos program other than iDos (LITERALLY Dosbox (says it if u edit PLAY.bat to just @echo off)) for iPad?
bimp
dosbox does not support xp.
it Supports win 3.1
Don't bump a thread unless it hasn't been replied to for days.
When a Dosbox dev says use another program, take the hint...
Locked before it bumpsup and down...
