First post, by manic232
All of a sudden I have the most bizarre problem with my 3DFX Voodoo 5500 AGP. I have been using this for some time now and it's been working fine. I recently had cause to re install Windows 98 SE on my PIII system, I have the official V5 drivers installed, like I have done 1000 time before but for some paranormal reason I cannot change screen res higher that 640X480, the slider will not move, also the 3DFX tools state that the highest res possible is 640X480. What am I doing wrong? I just can fathom it.
Any help would be appreciated guys, many thanks.
My System: ASRock P4i65G MB, Win98SE, P4 2.4GHz, 512MB Ram, Nvidia GeForce 4 TI 4600, Sound Blaster Live! 5.1
Reply 1 of 5, by Skyscraper
Try changing the monitor type to Plug and Play monitor 😀
Reply 2 of 5, by manic232
THANK YOU!!! sorry for shouting but I'm happy that worked, thanks so much Skyscraper, it's really odd in all my years of playing with old computers I have never had this problem crop up before now but no matter you live and learn. Thanks again mate 😀:):)
Reply 3 of 5, by Skyscraper
Im glad it worked 😀
Reply 4 of 5, by Maraakate
I've had this problem happen when using KVM switches. If I start up the computer but the switch is not showing that particular computer during the boot up sequence the monitor defaults to 640x480 with no options. Though, I could probably specifically tell it to always use the particular monitor driver or get a more expensive KVM switch that shares the DCC information.
Reply 5 of 5, by PhilsComputerLab
I also ran this issue on one particular Asus monitor, as well as when I used a video splitter. Good to hear it's sorted 😀
