Worst video card ever, again
Reply 20 of 105, by F2bnp
swaaye wrote:
alexanrs wrote:
Did you have the DDR2 variant by any chance? I had one and, yes, that thing is pretty slow. The true non-cheapo 8600 with GDDR3 memory was supposed to be decent, but I never had one of those.
The problem was NV initially wanted $250+ for these chips that were about 1/4 an 8800GTX. The initial D3D10 midrange chips were just a rip off. Radeon HD 3800 and GeForce 9600 were much better.
True. The 8600 were not the great mid-range parts that the 6600GT and 7600GS/GT were. 7600 GT was usually faster or on par with the 6800GT AFAIR, 8600GT couldn't touch the 7800GT, let alone the 7800GTX/7900GT/GTX.
The 9600 GT was really nice, fast and inexpensive, I upgraded a friend's Core2Duo at the time, he really wanted to play Call of Duty 4 and 5 and the 9600GT was a great deal for my budget-minded friend.
Reply 21 of 105, by Davros
Nvidia nv1
Reply 22 of 105, by Putas
HighTreason wrote:
Whatever that SiS thing was in the SiS 530 chipset. Often throws a fit when asked to do anything at all. I didn't mind the 6326 though, that had a purpose at least and was dirt cheap.
That is funny, I believe that the 530 integrates 6326 with bigger texture cache, were there other differences?
Reply 23 of 105, by HighTreason
You sure? If so, I am probably getting mixed up with a different chipset. Whatever it was, it was made by SiS and it was common in Time systems on the ECS boards they had. Of course, it is also possible that they were just a 6326 in a crappy configuration but I am sure they needed different drivers and I guarantee the performance was lower because I upgraded on to a PCI 6326 card years back which improved performance dramatically.
Reply 24 of 105, by Zup
Davros wrote:
Nvidia nv1
Again... why?
Maybe it's such a bad card that does not need explanations, but I'd like to know your reasons.
I'm selling some stuff!
Reply 25 of 105, by Darkman
The worst one ive used was probably the original S3 Virge . Slow 3D , average 2D , and what I would consider to be sub par image quality (maybe I was spoiled by the Matrox , ATI and 3DFX cards).
Reply 26 of 105, by Scali
Zup wrote:
Davros wrote:
Nvidia nv1
Again... why?
I guess it was a 'useless' card more than anything. Its unique rendering method meant that it couldn't really handle conventional triangle workloads from D3D or OGL very well.
When you had games that were specifically developed for the NV1's rendering method (mostly ports from Sega Saturn, which uses a similar approach), I don't think it was all that bad. But the rest of the world went in another direction, leaving the NV1 high and dry. I think nVidia recovered quite well though 😉
Nice video covering the stuff: https://youtu.be/jChtlWNIAL4
Reply 27 of 105, by HighTreason
The NV1 doesn't make my list for various reasons. The main one being the same reason several other cards aren't on my list; it was a first attempt, so it was allowed to fail. nVidia learned quickly and replaced it with a decent card two years later - though we did nearly get an NV2.
Reply 28 of 105, by Scali
Well, I have somewhat of a soft spot for stuff that may have been a commercial failure, but wasn't a technical failure. The Commodore Amiga for example. As for 3d accelerators, I've always liked the PowerVR chips as well, with their innovative tile-based deferred rendering. They had problems similar to the NV1: their rendering method had some idiosyncracies that made it difficult to run D3D/OGL code properly. Although not as badly as the NV1, it was mostly a case of code being written in a sloppy way so the driver's heuristics could not determine the beginning and end of a frame properly. Which is something that is required for deferred rendering to work properly: you need to know when to defer, and when to render 😀
Reply 29 of 105, by NJRoadfan
One thing I always found interesting about the SiS 6326 is despite being "crappy", it had excellent driver support! Full support for stuff like OS/2, DOS AutoCAD, and even Windows 3.1x. The VGA BIOS even claims to support VBE 3.0 too.
Reply 30 of 105, by swaaye
6326 also has MPEG 2 decode hardware. I don't know if it's any good though.
Reply 31 of 105, by 386SX
Only motion compensation right?
By the way when I tested this card (PCI) I was also quiet impressed by drivers and general compatibility. Obviously for the time it was intended.
Reply 32 of 105, by Marquzz
Surprised no one mentioned two cards that became very hyped but failed helplessly; SiS Xabre and S3 Chrome-series.
After a few years ATI and nvidia had played around the scene, these two were about to do a sprakling comeback. I remember especially the S3 Deltachrome that was going to perform as the top ATI/nvidia cards at a much less price.
I think the failure of SiS and S3 had a lot to do with poor drivers. They probable didn't realize that 3D-gaming was at least as much software as hardware
Reply 33 of 105, by Scali
Haha, perhaps because nobody had those 😀
I can also recall the Volari cards. Never seen one of those either.
Reply 34 of 105, by ODwilly
I like the DDR3 8600gt because people toss them all of the time and they make great Aero cards for a Vista or 7 machines with crappy GMA graphics.
Reply 35 of 105, by Tiger433
I has 8600GTS from Gigabyte and I played Gothic 3 even in FullHD, also Serious Sam 3 was playable on that card on medium. But that card died few days ago and I must use GT210 which is very slow card even aero in 7 slowed down a bit compairing to 8600GTS and I don`t like that card. In my opinion GT210 is a bad card and worst is GeForce 4MX440, slow, without shaders, card for nothing, even Radeon 9200 or 9000 are far better.
W7 "retro" PC: ASUS P8H77-V, Intel i3 3240, 8 GB DDR3 1333, HD6850, 2 x 500 GB HDD
Retro 98SE PC: MSI MS-6511, AMD Athlon XP 2000+, 512 MB RAM, ATI Rage 128, 80GB HDD
My Youtube channel
Reply 36 of 105, by Marquzz
That's true 😀 Everyone was like "yes yes yes...reviews...no."
Volari, yea, they were more or less a paperlaunch that never saw retail. At least not in Europe.
Reply 37 of 105, by kanecvr
Strongly disagree with you here. While there are indeed S3 Virge cards with horrible output quality (cheap brands like colormate) a proper specimen made by a reputable graphics company has great output quality. My ELSA (Winner 3000) and Diamond (Stealth 2000) S3 Virge cards look as good as a Millennium II all the way up to 800x600 / 32. Maybe even 1024x768 / 32. At 320x240 or 640x480 the S3 wins hands down due to better compatibility. The problem with Trio and Virge cards is finding a good one, as 70% of the cards out there are pure cheap crap.
I do agree that 3D is crap, but the millennium isn't much better.
Reply 38 of 105, by GeorgeMan
I had an XGI Volari V3.
It had pretty good picture quality/sharpness.
I guess that on 3d it'd suck, but the "competitive" FX5200 and Ati Radeon 9200 also did not exactly stand out... 😜
I had trouble finding appropriate drivers though.
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 39 of 105, by 386SX
Well if you should consider the "hype" factor, well the list would be much longer. 😁
