First post, by npsiegfried
I have the original install disks for QuickBASIC 4.5 but I can't figure out how to install correctly since I have no floppy drive. I tried making ISO files for each disk and mounted them both using IMGMOUNT and even tried switching between disks using Ctrl+F4. I keep getting a message saying there's not enough room to install it on the drive. The second part of the install insists I insert the second disk in drive A. Is there anyway around this? I tried just about everything. I really want to install this!
