First post, by oldpaddler
oldpaddler
Offline
DrawPerfect installed under DOSBox works OK
except the custom config file seems to be ignored
DOSBox status window shows "CONFIG:Loading primary settings from C:\Users\Bob\AppData\Local|DOSBox\dosbox-0.74.conf"
Shortcut Properties are:
Target: "C:\Program Files (x86)\DOSBox-0.74\DOSBox.exe" -exit -conf "c:\dosfils1\drawperf\drawperf.conf" "C:\dosfils1\drawperf\dr.exe"
Start in: "C:\Program Files (x86)\DOSBox-0.74"
Changing -conf to -userconf did not help
I installed in DOSBox because installed under VDOS I get no mouse control.
The program runs in graphic mode.
Any suggestions?
