First post, by ibm5155
It's more about imagination, but, what socket/slot would you want they to release a special version and the dream specifications 😁
Mine would be:
a Super Socket 7 processor, 1GHz clock processor that could downclock without any problem to 66MHz, and also some virtual downclock that could reach 4MHz.
The processor should have 256kb L1 cache and 4mb L2 cache (and both could be disabled).
the FSB should work fine btw 66MHz at max 133MHz.
the FPU should be much more powerfull than a K6-III+ and had the performance as a Pentium 3 1GHz coppermine.
also the TDP should be around 3 - 10Watts.
This way I would have the perfect cpu for all almosy any era of gamming 🤣
