Pentium 4 1.6 GHz vs Celeron 2.0 GHz
First post, by xan1242
So as the title suggests, I am wondering which is better.
Both CPUs are from the Willamette family and currently the first one is in use.
I am just trying to build a computer from spare parts, if anybody is wondering why.
In general, out of PC games, I'd only really play Unreal and maybe UT2004, games till '06 in general.
I would use it for some emulation purposes too, but I really don't know if the other is better at the moment as I can't really start testing (lack of thermal paste).
From what I recall the Celeron running I was disappointed, though that was on another motherboard. (currently in use is an ASUS P4B266 rev 2, it has a CMI8738 yay)
Reply 1 of 22, by PhilsComputerLab
Can you provide more detailed model numbers /descriptions? Cache, FSB, core names.
YouTube, Facebook, Website
Reply 2 of 22, by Arctic
I would go for the Pentium 4 1.6GHz! The lower amount of L2 cache in the Celeron slows it down in 3D games.
Maybe you can overclock it to 1.8GHz.
I had the same system in 2001 with a Geforce 3 Ti 200.
Reply 3 of 22, by noshutdown
if both running at stock clock, i would say it depends on the chipset:
using 845 mainboard and pc133 sdram, p4-1.6g would be faster
using 850e mainboard and pc800 rdram, celeron-2.0g would have the edge
by the way, celeron-2.0g is based on northwood core so it would be fairly easy to overclock to 2.66g, pentium4-1.6g is much harder to overclock.
Reply 4 of 22, by Tertz
To buy a thermal paste is not hard, so you'll better test these CPUs in apps you are interested in. Unreal, for example. As for emulation, you may compare the speed in DOSBox Quake benchmark and in Speed Test run in DOSBox.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 5 of 22, by Thandor
The Celeron 2.0 'Northwood' will be faster in general if you run it on the same platform as the Pentium 4 1.6 'Willamette'. As noshutdown mentioned you'll be able to overclock the Northwood better. With a bit of luck you can even run it at 2.66GHz using a 133MHz (QDR533) bus.
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 6 of 22, by havli
I did some tests of similar CPUs, maybe it will help you decide.
Reply 7 of 22, by Tertz
havli
Looks strange that P4 1.6 is 30% faster than P4 1.5 if there are same other conditions.
Would be interesting to see your full benchmark chart for CPUs.
Yamaha YMF7x4 Guide
Reply 8 of 22, by havli
P4 1.6 is Northwood - hence the 1.6A marking. The extra L2 cache really makes a difference. P4 1.5 is willamette core.
Full charts, yes that is my plan... but it will take a while. At the moment I'm working on part two of this article Re: CPU benchmark - part I. (1995 - 1999) It will go up to Athlon XP 1600+ / P4 1.5 Willamette.
Reply 9 of 22, by F2bnp
Stay as far away from the Celeron as possible. They are basically Pentium 4 CPUs with less cache and a slower bus. It's not really the bus that kills it though, but rather the L2 cache. P4 Willamette started at 256K and for good reason. Netburst performs like a dog with 128k L2 Cache and that's why the Celeron performed so awfully compared to its peers. It wasn't until the Celeron D hit the market that it started closing the gap significantly.
Had Intel put a little more cache on the Celeron, say 192KB istead of 128KB, I think it would have helped performance immensely.
Reply 10 of 22, by xan1242
Whoa, I just went to sleep after I posted the thread and I never got such a blast of a response out of one forum 😁
Sorry about that,
the CPUs in question exactly are:
Celeron Northwood
Pentium Willamette
I don't know why I thought the Celeron was a Willamette, really.
noshutdown wrote:
if both running at stock clock, i would say it depends on the chipset: using 845 mainboard and pc133 sdram, p4-1.6g would be fas […]
The ASUS board uses the 845 and yes, from what I've heard as well the P4 is harder to OC. I'm not very experienced with OC-ing on older boards, I'm worried about the RAM more than anything since I have a mishmash of 1GB stick and 2x 128 MB sticks of which one of is a DDR333 and other is DDR266.
I know but the closest store to my place has shut down and I'm really sad because of that, it was just a 5 minute walk away from me. 🙁
I do have some left luckily, I'm just an idiot for not searching.
I'm thinking so as well right now since I do remember horrible load times and everything on an ABIT BL-7 (SDR).
Reply 11 of 22, by Tertz
I've noticed other core. If the result is corrent, hence Intel's engineers knew about the problem with small cache and released CPU with it, harming its reputation on the start. Previous P3 had not optimal quantity of cache on the start too.
Yamaha YMF7x4 Guide
Reply 12 of 22, by Lukeno94
Indeed, the Mobile Northwood Celerons showed exactly that. They had 256KB of cache, and my experience with a Packard Bell Versa E400, which uses a fairly basic SIS chipset and a 1.5 GHz Celeron Northwood, has been pretty favourable.
Reply 13 of 22, by xan1242
So I have conducted some benchmarks and all of them went into P4's favour. I'll post results once I get to it.
Reply 14 of 22, by dr.zeissler
@Phil
I ordered a SCENIC-T with P4 1,6. Should be a good choice for a retro-gaming machine.
I am not sure what to use as GFX-Card for AGP4x. What is your advice? (Win9x/Win2k/XP no Dos)
I will put a 3dfx-Voodoo2 in it too.
Reply 15 of 22, by agent_x007
It did with Celeron D series 😀
Intel even increased FSB to 133MHz (or 533MHz QPB), while increasing cache to 256kB on Celeron D's.
Results were great compared to old one, BUT still kinda suck compared to Semprons based on Athnlon64 architecture...
Reply 16 of 22, by F2bnp
agent_x007 wrote:
It did with Celeron D series :) Intel even increased FSB to 133MHz (or 533MHz QPB), while increasing cache to 256kB on Celeron D […]
I know, I even said so. Just saying that Willamette and Northwood Celerons should have had more cache right from the get go. They knew 128KB wasn't going to cut it, but I'm guessing it was a little too competitive with their own Pentium 4 if they increased the cache to 192KB even.
So, they just waited until the Pentium 4 hit 800MHz FSB and much larger caches (512KB and 1MB with Prescott) and then introduced the Celeron D.
The Sempron 64s were kickass, no doubt about it.
Reply 17 of 22, by PhilsComputerLab
dr.zeissler wrote:
@Phil I ordered a SCENIC-T with P4 1,6. Should be a good choice for a retro-gaming machine. I am not sure what to use as GFX-Car […]
@Phil
There are lots of options 😀
Seeing you got a V2, then I would go with a GeForce. Maybe a GeForce2 or 3?
Reply 18 of 22, by dr.zeissler
Thx 😀 I thought about an Radeon 8500 AGP too.
Reply 19 of 22, by Carlos S. M.
Netburst architecture was really dependent on Cache and bandwidth. The Willametter and Northwood Celerons had practically the same IPC and the low 128 KB L2 kills it. It usually loses to lower clocked P4s and in the worst case, to some Pentium III (an 1.4 ghz Pentium III can esaily outclass a P4 Celeron).
Oddly, mobile Northwood Celerons came with 256 KB L2 unlike the desktop version.
Also check your motherboard model and CPU support, if it supports FSB 400 only and Northwood, you can take something like the Pentium 4 2.0A which is faster than both CPUs, if the motherboard supports FSB 533, you can go with an even faster Pentium 4 2.4/2.53/2.66/2.8 ghz (3.06 ghz if the motherboard supports HT)
