First post, by Megadisk
Hello,
I have a Gateway GT5678 (MS-7399 mobo) PC that I'd like to install a floppy drive into it. This PC came with a "portable media drive bay" instead of a floppy, but it can easily be replaced for a FDD and the motherboard also has a connection for it.
Now, I have many spare Dell FDD's with ribbon cables but none of them seem to fit the GT5678 motherboard. The connector still has the 34 pins layout (missing a couple of them), but one single pin is reversed compared to all of the ones I've ever seen.
Does anyone knows if this is some sort of proprietary connector?, It looks like if I drill a hole on a dell ribbon cable it could fit, but I'm unsure about the pinout. Any help is much appreciated.
A couple of crappy pics.
