First post, by markot
Are there any conversion kits that could be used to get -5 volts from a modern PSU where the -5 volt wire is missing?
Reply 1 of 11, by PhilsComputerLab
There are kits for ATX to AT that do that, but I am not aware of an ATX kit.
However, StarTech is still selling new ATX power supplies with -5V. And older, but decent brands / models, can be had second hand. Personally I just don't use ISA cards that need -5V.
Reply 2 of 11, by markot
I have understood that every ISA card (e.g. sound cards) would require -5 volts. Am I wrong? How does the ISA bus work if -5 volt is not available?
Reply 3 of 11, by alexanrs
Only a few cards need the -5V line. One of the very early SoundBasters, some PAS cards and the LAPC do need it.
You can always do a little mod and add the -5V line using a voltage regulator from the -12V line.
Reply 4 of 11, by PhilsComputerLab
Yup that's wrong 😀 But it's a good kind of wrong 🤣
Popular cards that need -5V are the Roland LAPC-I, the Sound Blaster 2 and PAS 16. Put another way, what sound card are you worried might need -5V?
Reply 5 of 11, by markot
I have just thought that it would be a requirement to have always -5 volts for sound card. I found also some information on this website:
http://pinouts.ru/Slots/isa_pinout.shtml
So if the pin 5 is missing, then -5 volts would not be required if I have understood correctly. It is good information, then I could use modern ATX power supplies too if sound cards doesn't require this voltage.
Also found this discussion: ISA Cards & Devices Requiring -5V
Reply 6 of 11, by PhilsComputerLab
Yup.
I've been using modern ATX power supplies for a long time. Even with 386 machines through adapters. Not having -5V is no issue unless you use a card that requires it 😀
Reply 7 of 11, by Malvineous
What happens if you use a SoundBlaster 2.0 (for example) with a PSU that doesn't have -5V? What part of it wouldn't work correctly? I'm guessing it uses the negative voltage during the DAC stage, so the joystick port would work fine but the audio output would have half the waveform cut off?
Reply 8 of 11, by PhilsComputerLab
https://youtu.be/8QXmxdiNWIs?t=2m24s
Reply 9 of 11, by Malvineous
Fascinating! What a great video. That answers my question in the best way possible - thanks for that!
Reply 10 of 11, by Brickpad
Thank you! I have been searching everywhere to find an answer to this!
Reply 11 of 11, by Dant
Actually, there's a guy on eBay that makes custom adapters for PSUs http://www.ebay.com/itm/251854771572?_trksid= … K%3AMEBIDX%3AIT <--That's a 24 pin ATX to 20 pin ATX with a -5v regulator. He has a 24 pin to 24 pin and an ATX to AT with the same thing (As well as an ATX to AT with -5v and a dummy 3.3v load for some power supplies that won't work without load on the 3.3v rail)
