First post, by Kaiketsu
Okay so...
this is the motherboard of the PC I acquired:
Seems in good condition, tho it obviously lacks RAM, but I can get that cheap. (keep in mind that this is an image from the internet. I know I have the same mobo, so it's not as pristine, probably 😜)
The issue in question is: is this enough to really play old games? I recall my 286 had massive hiccups on certain games, like "trolls".
Can't complain cause I got this one for free. It supposedly works. I will keep it, but I'm afraid it might not be enough for a retro-based PC to replace DOSBOX.
Reply 1 of 5, by Skyscraper
As its a 16MHz 286 its fast enough to play some games šŸ˜€
With a VGA video card you can expect to be able to play the same games as you would be able to play on a 386SX-16. Most games from 1988 - 1991 and some games from 1992 - 1993 will run well.
Reply 2 of 5, by Malvineous
Wow, a barrel battery that hasn't leaked! Maybe you should cut it off while you still can!
Reply 3 of 5, by Kaiketsu
Well this is an internet photo. Mine looks less fun:
Reply 4 of 5, by Malvineous
Oh sorry, I thought you meant the earlier photo was from the person who gave you the board. Looks like you got a nice haul of stuff there! Including a few hard drives! They look like IDE as well?
Reply 5 of 5, by Kaiketsu
yes. There's also a 3,5 drive, a 5,25 drive (yeaaah :3), two IDE HHDs, and a really old dial-up modem. Lots of goodies, just no ram. Not sure if everything works yet, I need to dismantle everything and test the MoBo itself. The 30-year old PSU is also intact and working, but I have second thoughts about using it now.
