Maraakate wrote:Also, how well does it work with Quake 1 and 2?  Is it fairly decent like the Sega Master System?  The SMS had a few 3D games that didn't look all that bad.  I know I shouldn't expect some huge VR world, but if it looks a bit like it's popping out at you without too much goofiness from the view world I'm interested!
To be honest I haven't used it much in its native form. I seem to remember Windows 3D games like Unreal worked well enough, but I only tried it a couple of times. I bought the whole set for $1 so I could use the glasses with a homemade serial port box and run DOS stuff like Descent 1 & 2 and Rend386 - which works really well! Through a good CRT monitor they look pretty good, the 3D effects work well (although better at night than in a brightly lit room during the day.)
There is also a 3-pin mini-DIN so you could use Nvidia-style glasses if you want. A bit more info & pics of my setup in this post.
Edit: Doesn't look like the passthrough dongle is user-openable unfortunately - no screws. I don't want to damage it trying to crack it open.
