stickies
First post, by josh
is there any chance that some of the basic issues could get stickied threads? for example, i bet all the optimization you can do to vdm sound has been posted many times, but when i try to look for it in search i'll get 1000 threads and after rifling through about 20 i gave up. also all the multiple questions that people ask screw it up because the reply's to those questions are "it's been answered, search for it" so now when i search i just get 10 answers like that.
search has helped, i mean it got master of magic running for me, but now i can't save, which i read somewhere how to fix it but it didn't. don't care much because continue game works at least. and i'm looking for something to speed up the battle parts that lag for me, everything else runs fine, well and the sound studders but i don't care about that, except that they're probably related. so can anyone give me some links maybe?
Reply 1 of 3, by josh
holy crap, i found what i was looking for when searching for something else entirely, what luck. i still do recommend some stickies for basics though.
Reply 2 of 3, by Guest
when i say basics, i just mean common problems, or update on the faq page but as the site seems to be dead, ah well. just one last question which is probably retarded. in the tutorial it says "You then right-click the program and choose "Run with VDMS" to start the game and play. When you quit, you will find that VDMSound has created a shortcut for your startup program". for me it does not create a shortcut file. i checked the game i was trying to run's folder, the vdm folder, and the desktop, then did a search for .vlp just to be safe. this is how i'm directed to solve my problem, i have to change the properties of the shortcut pointing to the program. so is there any other way to create this shortcut, or another way to alter the settings of the game? i searched through the config file in the vdm folder but couldn't find the, i want to say dpmi options to change their properties.
Reply 3 of 3, by Guest
ok sorry for all the dumb questions. i think my problem was with search in general, and now that i know how it works it's much easier.
Search for any terms or use query as entered means AND.
Search for all terms actually means OR for all your selections.
and AND, OR, NOT do not work which was my problem, but once you click on that wonderful "search for all terms" it works much better.
and anyone know how to get it to save/load on MOM? i tried a few things with no luck, but everything else is fine.
