First post, by paulo_becas
I was wondering if someone can help me out here.
I'm having issues runing SimTower on my 486, When i start the game here what happens
You can see the specs of my PC on my signature.
Things i've done...
-Decreased amount of memory to 32mb
-Tried instalation several times from diferent media
My thoughts... this is strange because i use to play this game before on the same computer but a few things have changed since then, i've swaped tha graphic card, i use to have a SiS 6326, increased the system memory and added a 10/100 ethernet card (3Com).
I've already decreased the amount of memorybut the issue is the same, could this be a graphics problem?
Is there anybody who has the same graphic card (Matrox Mystique) as me and manage to get this game working?
I still have the SiS 6326 here but i don't want to change unless it's really necessary.
Yesterday a friend gave me an S3 Virge, for my research it looks this card is one of the best for old PCs...
Help please 😒
AMD Am486/Am5x86-P75 DX5 133 Mhz-64Mb Ram
S3 Trio 64V2DX 2 Mb
Soundblaster AWE64 Gold+Music Quest+MT-32+MU80
LAN-3Com
1.44 3,5 Epson Drive+1.2 5,25 Mitsumi drive+Iomega Zip 256Mb
8gb HDD,4Gb CF HDD
HP CDRW 9200
http://jp-retro.blogspot.com
Reply 1 of 12, by Roman78
Your win3.11 looks remarkable like windows 95.
Do you have the latest Matrox drivers installed? Try a little older version of the driver.
Reply 3 of 12, by paulo_becas
Thank's for the reply
Thank's i have Calmira II installed and it looks great but it's still work in progress, i'm customizing what i can to looks even greater.
I'll see what i can get, i have the original Matrox CD, i'll check it out and see what version i have,
I solved IE5 issue by decreasing the amount of memory, now i can install it without a problem
DosFreak wrote:
I already check that thread, i have 4mb of video memory so it doesn't apply to me
S3 Trio 64V2DX 2 Mb
LAN-3Com
8gb HDD,4Gb CF HDD
HP CDRW 9200
Reply 4 of 12, by paulo_becas
Browsing the web with 3.11 sucks big time 😵
S3 Trio 64V2DX 2 Mb
LAN-3Com
8gb HDD,4Gb CF HDD
HP CDRW 9200
Reply 6 of 12, by paulo_becas
That makes sense, no, i don't have a printer installed but i will surely try that
S3 Trio 64V2DX 2 Mb
LAN-3Com
8gb HDD,4Gb CF HDD
HP CDRW 9200
Reply 7 of 12, by paulo_becas
Ok, just solved it by installing the true type fonts, here's how i did it.
Main - Control Panel - Fonts - Add - Choose the following path c:\windows\system - Select all - OK
Restart windows and that it, true type fonts installed and Sim Tower working 😊
S3 Trio 64V2DX 2 Mb
LAN-3Com
8gb HDD,4Gb CF HDD
HP CDRW 9200
Reply 8 of 12, by retrofanatic
That's great that you got it working. Good to know how to get it working if I run into the same issue.
I wonder if installing calmira ii messed up your fonts in the first place?
Reply 9 of 12, by filipetolhuizen
That's a good guess, since it changes the whole appearence. Seeing that "Gerenciador de Programas" really brought me back at the time. Win 3.x was so much fun, specially with programs like Afterdark and Icon HearIt/DoIt.
Reply 10 of 12, by paulo_becas
Don't know if it did, maybe yes because, like i said, i already played this one without any trouble.
I didn't have to install no printer, i just installed the true type fonts available in the system drawer under windows directory and that's it. Very simple.
I always loved MS-Dos and Win 3.11, back then my windows was full customized and i intend to do the same on this one.
S3 Trio 64V2DX 2 Mb
LAN-3Com
8gb HDD,4Gb CF HDD
HP CDRW 9200
Reply 11 of 12, by breech
Yoot Tower is the original version (Segasoft), I wonder if that was more compatible.
Reply 12 of 12, by hannelius
paulo_becas wrote:
i had the same thing...
for some reason windows 3.1 doesn't install the fonts
and you have to do it yourself...
and sim tower needs them...
