First post, by j^aws
- Oldbie
Anyone know what this 'Error Code: 02FF' means?
I get this message after I run TEST-SBP.EXE. It auto-detects the SB Pro at 220h, then displays the aforementioned error message and freezes. I've tested games and FM works when I chose Adlib, but PCM doesn't work when I chose SB, and tends to freeze the PC. I can't see any physical damage on the card.
I've tried:
- Slowing PCs down to 386 speeds
- Three different motherboards
- Changing to 240h, and different DMAs/ IRQs
- Disabling all other ports in BIOS
- Changed PSUs with -5v
- Removed all expansion cards except VGA
- Different versions of TEST-SBP.EXE
Maybe the card is just 'damaged' somehow...?
