SD Card as Hard Drive
First post, by rick12373
I have one of those adapters that lets me connect an SD Card to the IDE for my Compaq Presario CDS 520. It works well but the SD Cards I use with it at the moment are 256MB and 512MB. I need a bit more storage space. The drive has to be formatted FAT16 in order to work. I think the largest drive FAT16 can provide is 2GB. I am going to buy a 1GB SD Card but it means ordering it online because none of the stores close to here have SD Cards that small anymore. I have a 16GB SD Card spare right now, is there a way to format it to 2GB or less using FAT 16. If so, how?
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
Reply 1 of 30, by alexanrs
Once connected to the PC, FDISK itself should be able to do it.
Reply 2 of 30, by PhilsComputerLab
Yup. MS-DOS 6.22's FDISK creates max. partitions of 2 GB. Four of them at the most.
You can enter smaller sized though 😀
YouTube, Facebook, Website
Reply 3 of 30, by rick12373
I found a 2GB card anyway and FDISK was able to see it. The machine would not even detect the 16GB one. All running nicely so far.
SB 16 Value CT2770
Reply 4 of 30, by rick12373
I think I spoke to soon 🤣. I used FDISK to create a primary DOS partition and then it says "system will now restart". The computer restarts and it has not created the partition. It is a 2GB SD Card. I even tried making the partition 1GB instead. It can see the disk, it just won't create a partition. It doesn't give any error messages, it just says "system will restart" and when it does, there is no disk.
Any ideas?
SB 16 Value CT2770
Reply 5 of 30, by brostenen
"Format c: /u /s" and then reboot to do the OS installation part.
Reply 6 of 30, by swaaye
Is the 16GB card SDHC / SDXC? What about the 2GB card? Older readers won't read those newer types of cards.
Reply 7 of 30, by rick12373
I can't, after asking FDISK to make a primary DOS partition it says it is restarting the computer. After it restarts there is no hard drive to format. FDISK detects 1 fixed drive but will not create a partition, it just says restarting computer and I am back to square one.
SB 16 Value CT2770
Reply 8 of 30, by rick12373
The 16GB is an SDHC, so this is probably why that one does not work. The 2GB does not say SDHC or SDXC.
SB 16 Value CT2770
Reply 9 of 30, by rick12373
I found the problem. I am using a SD Card extender cable thing so that I can replace cards easily without having to open the case. When I plug the card directly in to the IDE interface board it works. Annoying...
SB 16 Value CT2770
Reply 10 of 30, by retrofanatic
Nice to hear that you figured it out. Sucks that the SD extender doesn't work...will using a 40pin IDE cable extender cause the same issue I wonder?
Reply 11 of 30, by rick12373
Not sure on that.
It detected and formatted the 2GB card, installed DOS 6.22 and then when it had finished and said to remove all floppies and restart, it hangs on boot...
SB 16 Value CT2770
Reply 12 of 30, by alexanrs
Try FDISK /MBR and see if it boots
Reply 13 of 30, by rick12373
Holy crap! That worked! Thank you so much. I had actually partitioned it to 1GB this time. I think I will try again now but try 2GB.
** Edit - The SD Card extension works now as well. Nice 😀
SB 16 Value CT2770
Reply 14 of 30, by retrofanatic
Nice indeed! Get to hear it works now.
Reply 15 of 30, by Thraka
So I was just thinking about this too..
SDHC are getting dirt cheap.. $7 for a class 4 which isn't too bad especially using it in an old PC where you're not reading/writing tons of data as fast as possible. If you mount it so that it is easily accessible you can easily pull the card and replace it which is great for swapping out entire systems on old PCs and not having to redo partitions.
Also, Instead of booting to the PC, hooking up network, copying files over that which is pretty slow on old systems, you can just plug it into your PC with the appropriate adapter, copy the files you want, and plug it back into the system and boot.
It seems lower sized SSDs are going to get harder to find as they start manufacturing the bigger ones, but SD cards are still going to be readily available in these smaller sizes.
Reply 16 of 30, by rick12373
Yep, it is nice. I have the SD extender mounted on the outside of the case and can switch SD cards in and out. It is very convenient.
SB 16 Value CT2770
Reply 17 of 30, by PhilsComputerLab
Same!
And I can buy them at the super market 😀
I've bought two models from eBay, but they haven't arrived yet.
Reply 18 of 30, by alexanrs
Just beware that, unlike CF cards, SD cards do not have the IDE logic built in. Therefore you are entirely reliant on the adapter's chip itself, which can be a problem with cheap stuff from China and more care and research should be put into choosing a good adapter.
Reply 19 of 30, by tayyare
What about this one?
http://www.ebay.com/itm/NEW-SD-SDHC-SDXC-To-C … 5oAAOSwHnFV2AaL
Anybody has any experience on these adapters? It will probably enable us to use SD cards in standard cheap CF to IDE adapters.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
