Dos 5.0 or 6.2? and AT wire setup
Reply 20 of 37, by alexanrs
Without the entire board it is harder to identify the correct model, and once it is identified it is not impossible (or even rather easy, depending on the maker) to get the manual which will provide the pinout for all headers.
Reply 21 of 37, by Nic-93
I cant really get a best picture of it.
Reply 22 of 37, by alexanrs
MSI MS5124
Manual here. It's got the pinouts.
Reply 23 of 37, by Nic-93
So it means they have to sit on the side like next to each other?
There is also a fan wich drives power from one of them.
Reply 24 of 37, by alexanrs
If that is how it is shown in the picture I can't argue with that. Also, polarity isn't important for speakers and buttons, and reversing LEDs won't hurt either (but they won't work).
Reply 25 of 37, by Nic-93
Alright, so evreything should be ready now, red wries on the right and black wires on the left,
Reply 26 of 37, by Caluser2000
have another look at the picture I posted earlier. Blacks go in the center...
Reply 27 of 37, by Nic-93
And they are in the center, but i have another problem..most of the lettor's on those small power wires to the varius lights and switches are missing their text.
Reply 28 of 37, by Caluser2000
You should be able trace where they came from. As for where they go on the mobo have a look at page 16 of the manual alexanrs linked to.
The attachment P16~P17.jpg is no longer available
Reply 29 of 37, by Nic-93
I am, and the pin setup i posted in my picture is the same, right?
Reply 30 of 37, by Caluser2000
Hook the HDD led to the two pins on the end where the gap is and see what happens.
Reply 31 of 37, by Nic-93
And just to clear up, the 2 black wires are in the middle.
Reply 32 of 37, by Nic-93
Oh, shot, i might need a new cmos battery.
Reply 33 of 37, by Caluser2000
That's certainly not uncommon.
Reply 34 of 37, by Nic-93
Useally the computer halts when not haveing a working battery, right?
Reply 35 of 37, by alexanrs
Does it get to the POST screen?
Reply 36 of 37, by Nic-93
oh, i cant say really, it didnt really have some activity,
Reply 37 of 37, by alexanrs
Check every component on its own, specially the video card and memory. Be sure to hook up a speaker to the motherboard, as it will beep if the motherboard detects errors before initializing the video hardware.
