no sound
First post, by Guest
hi I can't get any sound to play at all.
I'm using the built in sound card in my ABIT AV8 motherboard
Can someone help me?
Reply 1 of 13, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
a) Does sound work otherwise normally in Windows?
b) Do you know that sound in almost every DOS game must be configured?
There should be a program like SETUP/INSTAL/SETSOUND. It depends on a game...
Mirek
Reply 7 of 13, by Alexsource
My guess would be that you have bad drivers or something...
BTW, which motherboard/integrated soundcard?
I have a pcchips mobo with a SiS 7018 integrated soundcard and everything sounds peachy.
Reply 11 of 13, by MiniMax
Rank Moderator
Moderator
SDL (sdl.dll) is a library that DOSBox uses for a lot of stuff - like drawings graphics and play sound. SDL comes with DOSBox, but sometimes the latest DOSBox+SDL has problems - problems that is not present in an earlier version. That is why Alexsource suggested you got an older one, but I think it is a bit to early to go down that route for you.
You do not need a DOS driver with DOSBox. As you more or less has guessed, DOSBox (and SDL) uses the drivers that you have have in Windows.
For now, I would forget about getting your current to run, and instead get hold of another game. There must be some free demo-games listed somewhere on this board. Get the smallest one you can find that make some sound. Then try to get that to work with DOSBox instead of your current game. If a small demo works, then DOSBox+SDL+Windows works...
_________________
Reply 13 of 13, by MiniMax
Rank Moderator
Moderator
1. Use the search funktion.
2. Post in DOSBox/Games/Apps with a telling subject, e.g. "Monkey Island 1, no sound?"
_________________
