First post, by 386_junkie
- Oldbie
What, a, day!
I've done a marathon of testing today... and not using one of my main rigs either!
Today, i've discovered that the PSU on one of my main rigs is quite picky and tempramental about which motherboards it wants to run and which one's it does not. I went through a "to repair" box full of components I thought was broken... using a different AT case / PSU... to find they are actually working! Aside from being back-up in terms of parts I thought I had lost, I have re-learned something new again... just because your PSU worked fine in the past, does not mean to say it will stay that way! I still don't understand why most motherboards will work with it and some do not.
One other thing I would also note is; of the motherboards... the Bios each board has never seemed to give their beep codes as per, just a black screen.
So if you've just about given up... try a different PSU, no matter if your main rig PSU works well with most of your stash! AND NEVER chuck your broken components away whatever you do no matter how broken you think they are!
Anyone had similar experiences? If you've a box full of non-working components... try a different rig!
