swaaye wrote:There are a couple of tiny electrolytic caps that the kit does not include. Down by the southbridge IIRC.
The tiny caps don't usually need replaced although it's not a horrible idea if they are OST brand or Nichicon VR.
I've seen tiny Nichicon VR bloat en masse on older Intel branded motherboards. (Slot 1, skt 423, early skt 478)
They are only rated for 85˚C and should not have been used on motherboards to start with.
To make matters worse during the time VR were used most cases were not particularly well cooled.
Is rare but I have seen bad 22uF OST's near a chipset kill a whole board.
[adding]
I don't remember the specific model(s) ATM, but some Dell's in SFF/USFF chassis has issues with 22uF going bad due to poor airflow.
These were a generation or two after the famous SX/GX - 260/270/280 problems.
I think it was the Optiplex 745's. Not 100% sure.
