First post, by saturn
HWbot has some of the best overclokers off all time. I know I'm good, but dang...
The attachment 8csk21.png is no longer available
http://hwbot.org/submission/2533599_gradus_cp … ghz_2651.35_mhz
and 2.4ghz on a P3 1.4ghz
The attachment 420005.png is no longer available
http://hwbot.org/submission/746447_gradus_cpu … z_s_2447.24_mhz
How is it that this can be done? There has to be some trickery going on here. 😕
I know they cherry pick everything but still... 😕 Liquid Nitrogen can't be the only thing that lets them go that far. I done dry ice befor and never gotten this far.
Reply 1 of 16, by matze79
disable all caches and wait a hour for bootup and cpu-z ?
i didnt get more then ~1,8Ghz out of a Tualatin Celeron :>
Reply 3 of 16, by matze79
Maybe with PC166 SD-Ram and some Thing like Vapochill..
Reply 5 of 16, by saturn
The P3 I linked is useing pc166 ram.
Reply 6 of 16, by F2bnp
Insane results, that's for sure.
Reply 7 of 16, by firage
Liquid nitrogen. Very cool. 🤣 Probably an insane rig - would be cool to see pics of that second one with the insane FSB.
Other than that just a volt modded motherboard and a big bunch of chips to sift through, I guess.
My big-red-switch 486
Reply 8 of 16, by Arctic
I would love to see some benchmarks!
It should get close to low voltage / cache celeron Ms!
Reply 9 of 16, by F2bnp
No way in hell that's happening. At these kinds of frequencies they are lucky if they can get a CPU-Z validation score. The score tyuper posted has a SuperPi result which you can use to compare!
Reply 10 of 16, by mr_bigmouth_502
I'd like to see these machines pass some vigorous Prime95 testing. 😉
Reply 11 of 16, by saturn
Top clock speeds on HWBoot tend not to be stable.
But I bet some of the folks over there have gotten 2ghz-ish stable to the point that they can run p95 for a while.
If you ask me 1.6-1.8ghz would be the most that such a cpu would 100% stable along with the system. You can have a stable cpu, but ram and Northbridge too. it's harder than you think. I used to do comparative benchmarking in the past and I know my in and outs. I got out of it do to the cost and time. 1-2k on a New PC ever few months is hell. And a pc that thats only gets ued once or twice... 😵
Reply 12 of 16, by Marquzz
That is not the point. You just need it to be stable enough to pass the benchmark you are currently running. It this case, open cpu-z and saving a verification file and screen shot.
This has been discussed since people started to overclocking and benchmarking, always poeple arguing about stability and 24/7 usage.
Reply 13 of 16, by PCBONEZ
In my opinion overclocking a system to the point it has no practical use because it's unstable is nothing but a waste of time and you accomplish nothing by doing so.
Reply 14 of 16, by saturn
If you can get it stable it's more then worth it.
I had a x58 setup with a xeon running at 5ghz-ish once. Sure it was not practical but dang it was fast.
Reply 15 of 16, by sliderider
This. If you can't get it stable with a high end air cooler, it is useless. Putting a tank of liquid nitrogen on top of your CPU can destroy it because it makes the CPU brittle. When you try to lift the nitrogen tank off, you can sometimes end up taking part of the CPU, socket, and circuit traces along with it.
Reply 16 of 16, by F2bnp
If you go about thinking that way, yes it is pretty useless. But this kind of overclocking is just insane. It's meant to be a showcase and nothing more, it's directly related to the "Because I can" mentality that a lot of computer enthusiasts share. I find it incredibly impressive that a 1.4 Tualeron can even sustain 2.6GHz and boot into Windows.
