First post, by adalbert
I just fixed a 5.25 Mitsumi D509V3 drive I got with some PC scrap parts. It was working, but the problem was that the motor started to spin after the disk was inserted, but it didn't wait until the lever was closed. So the lever had to be closed while the motor was spinning, and that could possibly damage the floppy disk. After the lever was closed, the drive stopped spinning and the data could be read on the PC. But after removing the disk, sometimes the drive started to spin and refused to stop.
I discovered that this issue was caused by broken/bent endstop switch, which was being activated too early. It had a lever which was supposed to be pushed by the floppy disk, after the lever on the front panel was lowered, but it was badly aligned and I found it impossible to adjust the lever angle and height in a proper way - when it was too high, motor started spinning to early, and when it was too low, it didn't start spinning at all.
The attachment bad_sw.jpg is no longer available
The attachment bad_sw_2.jpg is no longer available
After looking at the mechanism, I realized that after the disk is insterted and I close the lever, a metal arm goes down. So I decided to desolder the old switch, and make a DIY solution, using three pieces of copper clad, a wire and some cables. I glued one piece of copper clad to the bottom part of the mechanism, and soldered a piece of wire there, which acts as a contact. It is soldered only in one point, in order to have some elasticity. Then I glued another piece of copper clad to that metal arm, soldered some wires, connected that in place of old switch and that's it.
The attachment copper.jpg is no longer available
The attachment diy3.jpg is no longer available
When the lever is completely closed, contact is made between these two surfaces I put there and the motor starts spinning. Problem solved 😁
The attachment in_out.jpg is no longer available
AT(X)Anything: a modular DC-DC PSU for old PCs (open hardware)
Reply 2 of 2, by Tetrium
Nice! I wonder if one of my 2.88MB floppy drives can also be repaired in a similar way. The disk doesn't spin but it seems to still be attempting to read the disk and as these types of floppy drives are nearly impossible to find, I never threw it out. I even kept a 1.44MB version of the same drive in case I ever needed it for spare parts.
Maybe it would be a fun idea to create a thread to show off your repairs 😁
I once repared a s370 board which had a broken CPU socket lever. It had broken right at the socket itself and the original lever was long gone even when I first got the board. In the end I figured out the plastic white lever was exactly the same as in many other boards (even sA) and I cannibalized one from a dead socket A board, lifted the top half of the socket (I had to use a flatbed screwdriver here), replaced the lever and clicked the top half of the CPU socket back in place and it worked! 😁
Too bad later it turned out the floppy connector on the board was dead, but that's what LS-120 drives are for 😁
My retro rigs (old topic)
Report spammers here!
