First post, by brostenen
- l33t++
Hi.
I have this 486-class machine, cramped into a baby AT case. I want to use a SCSI solution on this, just that the drives are running REALLY hot.
And I really fear they will go and die on me. Is there an undocumented way to lower the rpm on these drives?
I have the following drives to choose from, and of course the 50/68/80 pin adaptor, wich will let me use a 68/80 pin drives on a 50pin controller.
IBM Ultrastar DDYS-T09170 - 9.1gb 10.000rpm
and
IBM DCHS 4.51gb - 7200rpm
Both drives are running extremely hot, especially the DCHS (I have 2 of them, 3 counting the one in use), though it's "low" rpm, it still generates a lot of heat wich are dispatched through a type of cobber-ribbon.
Can something be done in these baby-at cases? And what would you all recommend me doing?
