First post, by Guest
HI @ all,
first I want to thank the developers of dosbox!!! I can play again "Z"! That's wunderful.
But I have still a problem: when I start dosbox in fullscreenmode I have still only a small area with dosbox and there is a huge black area around it!
Here is my dosbox.conf:
fullscreen=true
fulldouble=true
fullfixed=true
fullresolution=1024x768
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
The output must be surface otherwise the result isn't acceptable!
OK i hope you can help me
