First post, by Dauntless3788
I need help getting Hardball 5 to work with DosBox version 0.74.
I have downloaded the freeware version that is most commonly found and copied it into a folder for DosBox to use. If I try to just start the game it gives me the following error:
[FATAL ERROR: File GMTOOLS.C, line 317
note: These errors are often related to not enough free memory to disk I/O problems. See the manual for more information.]
So I use the VM option to allow Hardball 5 to use virtual memory. When I start it afterwards it goes to a black screen and sits there. On the console it endlessly repeats the line:
[DYNX86:Can't run code in this page!]
Seems odd how it doesn't work because the official DosBox compatibility site says that 0.72 should be fine. I can't imagine it would lose compatibility in a newer version. 😜
I have pretty much the basic mountings. I have a folder (DosBoxGames) used for my Dos games, as well as my laptops dvd/rw drive on D.
Any help would be appreciated.
Thanks!
