First post, by Willie
If you've ever experienced the "Warning: file creation failed" error on a Windows machine, here is a tiny, incomplete explanation of why it happens and how you can fix it.
DOSBox complains with this warning when the file is marked as Hidden in "real-life"
DOSBox can see the file just fine and allows access to it, but when "creating"/modifying this Hidden file, it fails and returns a warning.
So, how to fix it? Simply hop out to Windows and edit the attributes of the file (either right click -> Properties) or use ATTRIB -h in a command window.
Unhide the file and you should be set.
As the subject implies, this is what I did to get Supaplex to save my levels/player list. (PLAYER.LST and HALLFAME.LST)
Hope this helps someone. This problem probably doesn't happen with Linux since the attribute of a "hidden" file is to simply start with a period if I'm not mistaken. I imagine that DOSBox would have no troubles with this.
Thanks and good luck everyone!
Reply 2 of 3, by MiniMax
Rank Moderator
Moderator
Added: FAQ
Thanks!
_________________
Reply 3 of 3, by Krzyklo
In my case, when I encountered this error (File Creation Failed) in Win3.11 application, it helped to first set TEMP parameter in DosBox, before running Win3.11. Below is content of WIN.BAT file, which allow Win3.11 to create TEMP files in C:\
PATH C:\WINDOWS;
SET TEMP=C:\
WINDOWS\WIN.COM
Hopefully, it will help someone.
