First post, by feipoa
- l33t++
I have an ISA-based Photon Torpedo 564-TEK graphics card, which contains a Cirrus Logic GD-5434 chipset. Does anyone know why the normally black DOS background screen is green and how to fix it? I tried a Diamond Speedstar64 BIOS, which is based on the same chipset, but the green is still there.
I noticed that there has been quite a bit of hackery done to this card via added components. I am not sure if this is factory standard or not. Could it be causing my green display? I've attached photos.
