Dallas Clock Issues
First post, by bloodbath2you
Hey! Yesterday i adquired a p133 machine with a dead VIA RTC chip (via vt8828n) pin compatible to standarf dallas rtc... the issue its the machine tells CMOS battery low even with the battery mod and also im sure the mod is correct because the pins match correctly, and when the machine chip is without the battery it posts fine but settings are all lost when reset... 😒 any ideas ? Theres any way to plug a external battery to the mobo? The mobo is a PCChips m560 p166mmx. I dont even wanna think the chip is dead because that mobo was from the first pc i ever had *sigh* ...
Here's a shot of the modified chip
http://imgur.com/C1mZuSW
Reply 1 of 6, by Callahan
Strange, that mobo should be equipped with dallas 12887a chip... Why don't You change it with new rtc?
Cpq: ap550(2x1G/256k), sp750(2x900/2MB), 5100(2xpII300)
TD-30 2xP166 NT 3.51
HP Vectra XU 6/200 2x PIIOD 512MB FPM Banshee
Super S2DG2@550/2MB SCSI 15k V5 5500
P4T533-C P4 3,06 Ti4600
Dell T700r @P3-700 V3 3500
PR440FX-2x PIIOD Voodoo 4500 PCI r320 CT1920
Reply 3 of 6, by bloodbath2you
The vt8828 is equivalent, i have no way to find one of these here in chile, months ago saw one guy selling these as new but his announce no longer exists, also i dont have $$$ for it.
I have a question, in the datasheet pin 16 is NC but not negative, ive tried soldering the negative battery pin to GND pin 12, should this have an influence? Because maybe due propietary design of the chip the PIN 16 was just removed making no contact with the external battery from the original mod... or may i be wrong?
Another thing, or just maybe all batteries that i've tried are dead... but some of them were working good on other pc's... help 🙁
At the begining i thought it could be easy but all went to shit...
Reply 4 of 6, by Callahan
I bought five dallas 12887a chips for 5$ with shipping on aliexpress 😀
http://www.aliexpress.com/item/DS12887A-OEC12 … 2428102352.html
Look here for a tip with dallas mod:
http://www.mcamafia.de/mcapage0/dsrework.htm
http://www.classic-computers.org.nz/blog/2009 … attery-chip.htm
Reply 5 of 6, by Windows9566
my packard bell has a cr2032 battery, not a dallas chip
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
Reply 6 of 6, by bloodbath2you
Heey guys! Thanks for the help, i've found the mod and the chip were right, all of the batteries that i tested were just dead then used a new one and worked perfectly
