First post, by Totempole
- Member
I was going through my old hardware collection and dug out an old Powercolor Radeon 9800 XT which I recall purchasing for a fairly low price at a junk shop a few years ago. Since I bought it as a spare card for another machine, I never actually got round to testing it properly until today.
At first the card appeared to work fine, at least in the BIOS, but after a minute, it started to artifact slightly. In Windows 7 the card appeared to work fine, until I attempted to run a 3D intensive game. The game would run, but little white squares (artifacts) would appear all over the screen. A textbook case of a VRAM problem.
The card felt very hot, and I noticed that the ccoler had been removed at some point, so I figured I might as well apply some new thermal compound on both the GPU and the VRAM.
I tried the card again, but still experienced the same issues.
My next thought was to get a tool to lower the clock speed. I found a program called "ATITool". The standard clock speeds on my card were 412MHz Core and 365MHz Memory, which ATITool showed as 411.5MHz and 344.5MHz respectively. I dropped the Memory clock down to 338MHz, and like magic, the artifacts disappeard (At least within Windows).
The card still seems to be running very hot. You could fry an egg on the copper plate at the back that cools the VRAM on the top of the card. According to ATI Overdrive, the card is running at about 72C, which I believe to be within spec. ATITool shows the temp as 52C. The plate on the top seems to be closer to about 90C, but I'd have to attach a Temperature sensor to know for sure.
Now that I've bored you with all the details. I'm left with 3 options for this card.
1. I could buy a new cooler, in the hopes that it might perform better. My local computer dealer still has stock of the old Vanteg Iceberq 6.
2. I could leave it the way it is, and somehow edit the BIOS and permanently lower the Memory clock to 337.5MHz or less.
3. I could do both 1 & 2.
My only issue with the Iceberq 6 is that it doesn't seem to provide adequate VRAM cooling. All you get are 8 tiny heatsinks for each VRAM Module. Since VRAM temps are the main concern, I'm not sure if it's worthwile replacing the current tooler.
Below is a picture of my card for reference:
... and a small picture of the Iceberq 6
Any advice or suggestions would be much appreciated.
Do you think that replacing the cooler is the answer? And if so, do you think the Vantec Iceberq 6 is a suitable upgrade? Or should I just try and permanently lower clock speeds?
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
